Warning message
Cluster Managment and JVM 1.4.2
Is there a why to make the Cisco Cluster Manager work with JVM 1.4.2? I get an error CMS notinited when I try to open the Cluster Manager with IE 6 and JVM 1.4.2
What I get in the Java Console window is the following.
Java(TM) Plug-in: Version 1.4.2_01
Using JRE version 1.4.2_01 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\luker
Proxy Configuration: No proxy
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
Java plug-in version is 1.4.2_01
CodeBase - http://167.xxx.xxx.2/
Host - 167.xxx.xxx.2
Port - -1
File - /
Launching CMS using plug-in caching - http://167.xxx.xxx.2/cms_13.html
java.lang.NullPointerException
at sun.plugin.cache.CachedFileLoader.writeHeaders(Unknown Source)
at sun.plugin.cache.CachedFileLoader.createCacheFiles(Unknown Source)
at sun.plugin.cache.CachedFileLoader.access$200(Unknown Source)
at sun.plugin.cache.CachedFileLoader$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.plugin.cache.CachedFileLoader.download(Unknown Source)
at sun.plugin.cache.CachedFileLoader.load(Unknown Source)
at sun.plugin.cache.FileCache.get(Unknown Source)
at sun.plugin.net.protocol.http.HttpURLConnection.connectWithCache(Unknown Source)
at sun.plugin.net.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.plugin.net.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at sun.plugin.net.protocol.http.HttpURLConnection.getHeaderField(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at sun.applet.AppletClassLoader.getBytes(Unknown Source)
at sun.applet.AppletClassLoader.access$100(Unknown Source)
at sun.applet.AppletClassLoader$1.run(Unknown Source)
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at lk.d(Unknown Source)
at cl.l(Unknown Source)
at cl.<init>(Unknown Source)
at lk.<init>(Unknown Source)
at cisco.dsbu.cms.main.CMS.init(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Thanks for your reply Robert - I have read that info but my question is, is there anyway to make the 1.4.2 work with the switch CMS code. I know that the documentation says to use the 1.3.1 but I have other devices that need the 1.4.x JVM. They can't be made to work with the 1.3.x because of the feature set difference. So I was hoping to find a working around to use just the 1.4.2 on all my devices. So far the 3500/2900 series switches I have are the only ones that give me a problem.
Thanks again for you quick response.
Richard
