ROUTER PERFORMANCE
Sep 12th, 2003
Hi ,
Please can anyone suggest commands on
1) If router is low on memory
2) What are the active connections at the minute
3) How much CPU utilization is on the router .
Any other performance links appreciated .
Mibsun
liviu.gheorghe Fri, 09/12/2003 - 06:49
  • Bronze, 100 points or more
1) show mem free - to see the memory status of your router and sho processes mem - to see memory allocation by processes
2) To view active connections/flows through the router you must enable "ip route-cache flow" on the interfaces and then use the command "sho ip cache flow"
3) show processes cpu - to see cpu utilization
A good link for troubleshootin purposes is:
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Software:Cisco_IOS_Test&s=Verification_and_Troubleshooting
Cheers
