6509's MSFC BOOT IMAGE , CAT IOS AND MSFC IOS UPGRADE HELP NEEDED
Sep 13th, 2003
Hello switching experts ,
I have 6509 switch . And i will upgrade it to 24 Mb flash (MEM-C6K-FLC24M) . And after that i want to install following software iamges on cat 6509 switch :-
IOS 12.1(19)E (c6msfc-dsv-mz.121-19.E1)
MSFC boot image upgrade to:-c6msfc-boot-mz.121-19.E1
CAT IOS for supervisor upgrade :-cat6000-supk8.7-6-1.bin
I think so i have to install 1st MSFC boot image , secondly Cat ios for supervisor engine and at the end MSFC IOS 21.1(19)E . If this is not the correct method then please tell me the proper way . And please give me a link which describes step by step method to upgrade these softwares .
Prashanth Krishnappa Sat, 09/20/2003 - 22:12
  • Cisco Employee,
I suggest that you boot from the MSFC bootflash. The MSFC bootflash which is 16MB cannot fit both c6msfc-boot-mz.121-19.E1 and c6msfc-dsv-mz.121-19.E1. But in 12.1(19)E1, you do not need the boot loader image even for a MSFC1. So, just copy the c6msfc-dsv-mz.121-19.E1 image to the MSFC and boot using it.
cjrchoi11 Tue, 09/30/2003 - 12:30
Can you guide me based on our environment. supervisor-1A-2GE with MSFC1. the MSFC have 16M bootflash and 128M DRAM.
The current configuraiton on MSFC.
boot system flash bootflash:c6msfc-jsv-mz.121-11b.E12.bin
boot bootldr bootflash:c6msfc-boot-mz.120-3.XE1
can I upgrade to 12.1(19)E1a on the current enviroment with delete both current bootldr and IOS ?
