Warning message
DLSw Traffic as un-intersting
Sep 14th, 2003
I want to make DLSw as unintersting traffic to trigger the ISDN dial.
IS below alone is enough or any additions required
access-list 101 deny tcp any eq 2065 any
access-list 101 deny tcp any eq any 2065
access-list 101 permit any any
Martin
liviu.gheorghe Wed, 09/17/2003 - 12:46
  • Bronze, 100 points or more
The correct access-list to make DLSw uninteresting traffic for DDR is:
access-list 101 deny tcp any gt 11000 any eq 2065
This is because on the router configured for DDR, the DLSw traffic originates from a port higher than 11000 to port 2065 on the remote DLSw peer. The return traffic is from remote port 2065 to your port higher than 11000, which is not going to trigger your ISDN dial anyway, it's the problem of the remote router.
Cheers
m-villas Sat, 09/20/2003 - 20:32
I think
access-list 101 deny tcp any any eq 2065
also matches what ever the source port u said above, right?
Martin
liviu.gheorghe Sun, 09/21/2003 - 07:32
That is correct. The one I posted is more speciffic. Like I said, DLSw traffic originates from a port higher than 11000 to port 2065 on the remote DLSw peer. This way you can be sure that only DLSw traffic gets match by this entry of the access-list.
Cheers
