NATing
Sep 14th, 2003
I have two networks with different ip range and i want use nat on my router .i have two servers in my network which i want to it to see the other one servers in other network.i mean my two servers should be able to telnet and ftp to one of the server in another network.
how i can configure this from both the network the servers can able to telnet .
kyukim Wed, 08/11/2010 - 19:26
  • Cisco Employee,
Here are several links to good NAT documents.
NAT FAQ
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_q_and_a_item09186a00800e523b.shtml
12.4 NAT config guide
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_addr_consv_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Static NAT and Dynamic NAT
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093f31.shtml
Here is my simple config example
server, 10.1.1.1--------10.1.1.2 F0/0 router f0/1 11.1.1.1--------------outside world
router
int f0/1
ip add 11.1.1.1
ip nat outside
int f0/0
ip add 10.1.1.1
ip nat inside
ip nat inside source static 10.1.1.1 11.1.1.1  ---> map all tcp/udp ports
ip nat inside source static tcp 10.1.1.1 23 11.1.1.1 23   --> map only tcp port 23 for telnet
Hope this helps.
If you post more detail with how servers and routers are connected, then I can give u more specific example.
KK.
