Port Security Issues
Dear All,
I am sucessfully configured my LAN switches for port security auto shutdown and max-mac-count 1 in order to protect any body to plug they laptop or any other device to get connected with my network without authorized approval. I knew it is hactak but security is our prime consideration. We are using Ciscoworks2000 for managment and my switches are 6509 & 3500 series.
My concern here is, if any body violated the rule I should get email message by informing that, this purticular port is shutdown, based on that I can take some action. Somebody earlier suggested me that with the help of RTM or DFM we can configure some script to get that, but I didn't find any thing, please suggest or advice me...
Any help will be highly appreciated...
cminch Mon, 09/15/2003 - 03:29
I think you could get the information using RTM or DFM, you just need to set the rule up. You should also be able to see it if you have a syslog and the appropriate traps set. A lot of the script work for W2K is not very detailed and sparse.
Corey
