Warning message
Reinstalling LMS2.2
Sep 15th, 2003
I have the LMS2.2 maintenance kit that I used for upgrading my existing 2.1. However I would now like to reinstall from scratch and want to know if I have to install 2.1 first and then upgrade, or whether it is a supportable path to reinstall the 2.2 maintenance kit from scratch without the underlying 2.1 applications?
Nick
rmushtaq Mon, 09/15/2003 - 11:27
  • Blue, 1500 points or more
You should be able to use the same for the reinstall.
juliusj Tue, 09/16/2003 - 01:00
I've done it from scratch just using the LMS2.2 Maintenance kit.
The only thing was that DFM install wanted to be validated by sticking in the previous version of DFM.
Jurgen
