Warning message
3750 with a RPS 675
Sep 15th, 2003
A Switch 3750 is running over the RPS 675 after a power of from the Switch. How can I change the DC- power from the RPS to the Switch- AC- power, without the Switch reboot? (Network down)
owillins Mon, 09/22/2003 - 07:14
  • Silver, 250 points or more
From what I've seen the RPS does not back off and the switch did not use AC power supply till it is reloaded when you re-plug in the AC power supply. Use the sh env all command to check the status.
sroth Mon, 09/22/2003 - 23:24
What is with the RPS- „Active / Standby“- Button? Can I fix the problem with this button? Or make the Switch a reboot?
Thanks for your help!!!
Stefan Roth
