EIGRP retry limit exceeded
I am keep on getting "%DUAL-5-NBRCHANGE: IP-EIGRP 90: Neighbor 10.65.104.3 (Vlan118) is down: retry limit exceeded" from both VLAN 22 and VLAN 118.
There are total 22 VLANs in this MSFC, why only these 2 VLAN not holding the EIGRP neighbor?
I have tried shut and no shut on the VLAN interface, check the Spantree root, check the trunking... All looks fine???
deilert Wed, 09/17/2003 - 08:58
You have an issue with connectivity on these vlans , investigate all the switch ports on the vlans and inspect them for errors.
ruwhite Wed, 09/17/2003 - 10:53
This is a unicast failure, rather than a multicast or general failure.... Can you ping between these routers? Suppose you have two routers back to back:
A----B
A transmits some packet to B which must be acknowledged, multicast. B will acknowledge this packet using a unicast ack (actually, any packet sent back towards A can carry the ack). Assume that either the original multicast, or the ack, is lost. A sets a timer when it sends the original packet; once this timer expires, A retransmits this packet unicast just to B, and resets the timer.
If A attempts to transmit the packet 16 times, or through an entire dead interval, and never receives an ack, it will destroy the peer, and spit out the message you describe above.
From the frequency of the messages, it sounds like the inital hello, which is multicast, is getting through, but the next set of messages, which are unicast for the initial table exchange, are not. This would account for the two or three minute interval between bounces on each neighbor. I would bet that if you look at those bouncing neighbors, their RTO is always 5000.
The way to check on this is just to unicast ping to each neighbor, and see if it works. If it doesn't, you have a unicast failure in the link to those routers.
Russ.W
Russ, You are right in the target... I can not ping each other (Funny thing is the HSRP is working between these 2 MSFC)
I have checked the layer 2, the trunk port 1/1 on both switch are forwarding both VLAN 22 and 118, but on the trunk port 2/1, only A switch forwarding VLAN 22 and 118, but B switch is blocking...
Is it possible ths unicast going out from switch A port 1/1 and coming back from switch B port 2/1 and since switch B port 2/1 is blocking so the packet got dropped?
ruwhite Wed, 09/17/2003 - 16:11
HSRP uses a multicast to see the routers in the group.... As weird as it sounds, I would start with a show ip route for each ip address you're trying to get to on each router, and make certain it actually points out the right interface, etc, before doing anything else. Then I'd make a list of the mac addresses of each of the interfaces from the arp cache, and compare them to the cef and arp caches on the other routers.
Next, I'd start considering the switching side of things.
Russ.W
ruwhite Thu, 09/18/2003 - 10:32
It's in the output of show adj detail, or it should be:
2651A#sho adj detail
IP FastEthernet0/0 208.0.6.11(5)
0 packets, 0 bytes
0003E34866000003E34864A00800
ARP 00:08:32
Epoch: 0
Russ.W
Here is the sh adj detail:
USMPSARLRMSFC#sh adj vlan 22 detail
Protocol Interface Address
IP Vlan22 vlan21hsrp.us.schp.com(5) (10.64.22.1)
0 packets, 0 bytes
00000C07AC16
0004C15496820800
ARP 03:23:52
Epoch: 0
IP Vlan22 USMPS01DRMSFC.us.schp.com(5) (10.64.22.2)
0 packets, 0 bytes
0004C1DEEBC2
0004C15496820800
ARP 03:23:52
Epoch: 0
USMPSARLRMSFC#sh ip arp 10.64.22.2
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.64.22.2 36 0004.c1de.ebc2 ARPA Vlan22
USMPSARLRMSFC#sh ip arp 10.64.22.1
Internet 10.64.22.1 36 0000.0c07.ac16 ARPA Vlan22
USMPSARLRMSFC#
USMPSARLRMSFC#sh adj vlan 118 detail
IP Vlan118 USMPS01DRMSFC.us.schp.com(5) (10.65.104.2)
5 packets, 355 bytes
0004C1DEEBC2
0004C15496820800
ARP 03:21:52
Epoch: 0
IP Vlan118 vlan118hsrp.us.schp.com(5) (10.65.104.1)
173 packets, 16891 bytes
00000C07AC76
0004C15496820800
ARP 03:21:52
Epoch: 0
IP Vlan118 mpsarp01d.us.schp.com(5) (10.65.104.105)
1 packets, 62 bytes
0050565A1A0F
0004C15496820800
ARP 03:51:19
Epoch: 0
USMPSARLRMSFC#sh ip arp 10.64.104.2
USMPSARLRMSFC#sh ip arp 10.64.104.1
USMPSARLRMSFC#sh stand vlan118
Vlan118 - Group 118
Local state is Standby, priority 100, may preempt
Hellotime 3 sec, holdtime 10 sec
Next hello sent in 1.752
Virtual IP address is 10.65.104.1 configured
Active router is 10.65.104.2, priority 110 expires in 8.536
Standby router is local
1 state changes, last state change 1w1d
IP redundancy name is "hsrp-Vl118-118" (default)
USMPSARLRMSFC#
The VLAN 22 matches the MAC, but VLAN 118 is not learning MAC???
HSRP still working???
USMPSARLRMSFC#sh ip eigrp nei
IP-EIGRP neighbors for process 90
H Address Interface Hold Uptime SRTT RTO Q Seq Type
(sec) (ms) Cnt Num
23 10.65.104.2 Vl118 11 00:00:08 1 4500 21 0
24 10.64.22.2 Vl22 14 00:00:59 1 5000 21 0
22 10.64.4.2 Vl1 12 3w6d 4 200 0 1651510
Both VLAN 22 and 118 are not forming the neighbor.
Sorry, I was showing the wrong IP...
Here is the show for VLAN 118, all MAC are matching.
USMPSARLRMSFC#sh adj vl118 detail
0004C1DEEBC2
0004C15496820800
ARP 03:12:40
Epoch: 0
00000C07AC76
0004C15496820800
ARP 03:12:40
Epoch: 0
1 packets, 62 bytes
0050565A1A0F
0004C15496820800
ARP 03:52:49
Epoch: 0
USMPSARLRMSFC#sh ip arp 10.65.104.2
Internet 10.65.104.2 47 0004.c1de.ebc2 ARPA Vlan118
USMPSARLRMSFC#sh ip arp 10.65.104.1
Internet 10.65.104.1 47 0000.0c07.ac76 ARPA Vlan118
USMPSARLRMSFC#
ruwhite Fri, 09/19/2003 - 06:10
The mac addresses look right--is vlan 118 the right vlan to reach this address? I assume it is. It sounds like you have some other problem which is blocking unicast. Check the return path on the other routers, as well.
Russ.W
