Router 3725 does not boot
Sep 18th, 2003
Dear ,
A 3725 router with a E1 module(G703) does not boot.I have unpacked the router and configure it and it works only 2(two) days!!! properly.From the LED panel, only the PWR LED is solid green.SYS/RPS has no activity.
Would you please guide me what should I do with the router and what is the trouble with router..
Yours truely,
Bikash
deilert Thu, 09/18/2003 - 05:19
  • Silver, 250 points or more
can you plug a PC in to the console and connect via hyperterm and power cycle the box. Then post what you capture in your hyperterm session
cminch Thu, 09/18/2003 - 05:43
Also doing a sh ver, will also tell you what might have caused the problem, if you get that far. If you are in ROMMON you need to boot the system file by, doing a dir bootflash: or flash: and copy the file name usually a .bin file. Then tell it to boot then it should be up and running. there is still a lot you need to do to make sure this dosen't happen but we need to see how far you get first.
regards,
Corey
bikash_bd Thu, 09/18/2003 - 05:58
Dear,
There is none when i connect via console.no prompt no response, none,, nothing.SYS/RPS does not show anything
