Route groups
Answered Question
Sep 18th, 2003
Can somebody tell me what the effect of having two gateways in a route group with the same priority? i.e. will Call Manager try to make calls to both gateways, or alternate, etc...
Thanks.
Correct Answer by dugrant about 13 years 11 months ago
They are not load balanced by default, there is a CallManager service paramater that needs to be modified:
Reorder Route List :
This flag is only applied at the route group level. If this flag is set to True, all devices of the first Route group of a Route list, with the same device-selection-order will take turn to handle calls in the round-robin fashion. Note, this flag is not applied at the device level; that means, a device's ports with the same device-selection-order will not take turn to handle calls in the round-robin fashion. Furthermore, the one of the devices of the first Route group, with the same device-selection-order will handle a call firstly is indeterminate. If this flag is set to False, all of the devices of the first Route group, with the same device-selection-order will handle calls in the linear fashion.
This is a required field.
Default: false.
Overall Rating: 5 (1 ratings)
adignan Thu, 09/18/2003 - 14:34
  • Blue, 1500 points or more
If you have the same priority for gateways in a route group it is SUPPOSED to load balance but it is a little flaky in my opinion. It definately doesn't hurt anything to have a priority of 1 for both if that is what you were worried about?
Correct Answer
dugrant Thu, 09/18/2003 - 14:48
  • Bronze, 100 points or more
Default: false.
