2900 XL Restarts and Locks Up
Sep 19th, 2003
I have a 2924 Xl Switch and it restarts all of a sudden and also seems to lock up sometimes. It passess all the POST test fine however it simply restarts on its own after a while . Has anyone ever seen this behavior? I have also tried reloading a new image.
DALE FRANCIS Sun, 09/21/2003 - 01:22
  • Bronze, 100 points or more
Sounds like a H/W issue, are there any error msg's.?
If you do a sh ver it will tell you why it reloaded.
I have had similar isses with other devices which all it took was to remove and rebuild the config.
kpahare Mon, 09/22/2003 - 19:59
in my case it shows "Last reset from warm reset". and i dont need to make any config changes. sometimes simply rebooting the switch let the things working.
kpahare Mon, 09/22/2003 - 19:57
yes i do have this problem in plenty of my 2924-MXL-EN switches. they shows exactly same behaviour (Sometimes they Reboot all of sudden, or just gets hanged) with all the port LED's down and module LED amber. when i remove the fiber module (2922-xl-v) and install a Tx/Rx it works fine. it is very frequent and my customer is killing me.
dagaued Mon, 09/22/2003 - 20:06
So does anyone know how to fix this issue, or at least how to troubleshoot it.
kpahare Mon, 09/29/2003 - 05:40
in my case the ping to management ip, frequently shows 60 ms reply, and "show proc cpu" shows 50% utilisation whereas it is on no-load (no pcs are connected to it).
is something wrong with the hardware?
