Warning message
Pat Outside to Inside on PIX 525
Sep 23rd, 2003
Is the following configuration supported ?
PIX Version 6.3(1)
nameif ethernet0 outside security0
nameif ethernet1 support security95
nameif ethernet3 inside security100
access-list support-in permit tcp any host My_Host eq www
access-list support-in permit icmp any any
global (inside) 2 interface
nat (support) 2 172.24.1.0 255.255.255.0 0 0
access-group support-in in interface support
Basically I am trying to perform PAT from Low security to high security. It does not seem to work based on the configs above as the capture output shows the requested from low-to-high going out unchanged
Overall Rating: 4 (1 ratings)
wsitu Tue, 09/23/2003 - 10:12
We ran into a similar situation with Pix v6.2(2). After talking to TAC, here is our solution.
global (inside) 2 172.28.100.10
nat (outside) 0 access-list 101 outside
nat (outside) 2 192.187.81.0 255.255.255.192 outside 0 0
access-list 101 deny ip 192.187.81.0 255.255.255.192 any
access-list 101 permit ip any any
ayman Tue, 09/23/2003 - 10:24
Thanks !
Tha worked for me, I was missing the [outside] keyword after the NAT pool
Appreciated
Ayman
