Warning message
l2tp tunnel authentication
Sep 24th, 2003
I've set up a LAC with no l2tp tunnel authentication but I'm getting a challenge in the SCCRQ at the LNS.
lac conf..
vpdn enable
vpdn-group 1
request-dialin
protocol l2tp
LAC is a 7206xvr running 12.2(8) ZB8
lns debug...
4w2d: Tnl 91 L2TP: GOt a challenge in SCCRQ, model-pdsn
any help would be appreciated,
cheers
paul
dbellazetin Thu, 09/25/2003 - 06:46
Do you see the LAC send the challenge in the LAC debug ?
Daniel
kevitt Thu, 09/25/2003 - 14:57
yes...
also noticed that changing the local name in the LAC config has no effect...the hostname is always seen in the LNS debug as the source of the SCCRQ.
When i change the local name in the LNS the changes are seen in the LAC debug as expected.
dbellazetin Fri, 09/26/2003 - 05:35
Thats very strange. If you are running Cisco LNS, and LAC I would recommend trying to run L2F as the protocol instead of L2TP. It essentially works the same way. And if the behavior is still the same I would recommend opening a TAC case for this. The LAC is not behaving appropriately.
Daniel
kevitt Mon, 09/29/2003 - 00:48
thanks for the advice...I've now opened a case..
I've found that nothing within the vpdn-group has any effect, in the end I used radius to assign tunnel password. I can't use l2f as the LAC could be tunelling to non-Cisco LNSs within our core network...
cheers
paul
JAN MARIS Thu, 01/15/2004 - 02:08
I have also noticed this in 12.2(15)T7. Has this been acknowledged by TAC?
Jan
kevitt Thu, 01/15/2004 - 11:09
I've since found that if you use radius authorisation it overrides anything in the vpdn-group. As we use Radius to get the tunnel endpoint the vpdn-group settings are not used. Unfortunately there is no Cisco AVP that you can send to disable tunnel authentication via RADIUS so I've been told by tac. Therefore it appears that if you use RADIUS then you MUST use tunnel Authentication.
