Warning message
PIX and Inter Vlan routing ?
Sep 26th, 2003
Can someone help with this question ? I need to know if the PIX 515 does inter-vlan routing ? if yes, what PIX OS version ? thank you very much.
bdube Sat, 09/27/2003 - 06:32
yes, PIX supports VLANs. Then, passing packets between each VLAN is just like passing packets between any PIX's physical interfaces. You have to configure the rules you need.
If you want more advice, you should provide more details about your needs.
Ben
