Warning message
Locale Installation Error
Sep 29th, 2003
After the cancelation of a wrong locale with the "li-ffr-3.3.3-FRA.exe" the following error occurs:
"Error: Another Local Installer is running, please exit from the first and run again."
This must be a flag, that must be always set and now prevents the installation of the desired locale.
How can I reestablish the installation of other locales?
ivillegas Fri, 10/03/2003 - 10:32
  • Silver, 250 points or more
Try uninstalling and reinstalling the locale. If that doesnt help install - LI-FRA 3.3.3. which will sole the issue
gehasler Mon, 10/13/2003 - 01:02
Thank you.
Now is the problem solved.
Regards, George
