Warning message
Telnet Replacement
Sep 29th, 2003
I'm trying to get rid of clear text passwords being sent between management workstations and Cisco routers/switches (on the internal LAN). The client will not upgrade their IOS versions presently and therefore cannot benefit from SSH. Are there any other network management protocols that can be employed?
corey_hatch Mon, 09/29/2003 - 09:30
What about ppp authentication? Can you use this outside of the normal dialup context? Is there anyway to leverage this protocol?
