Configure PIX to block outbound traffic.
smartnet
I am trying to configure my PIX to block outgoing traffic to a specific IP range. Below is the line that I put into the PIX...
access-list inside_access_out deny ip any 63.246.130.0 255.255.255.255
access-group inside_access_out in interface inside
With this line of code, all outgoing traffic is block, no matter where it is going. Any idea what I am missing?
Michael Laro
mlaro@devine.com
gfullage
Always remember that there's an implict "deny everything" at the end of an access-list. By adding one line with a specific deny as you have, there's an additional line after that that says "deny everything else" and so everything is blocked. What you want is the following:
access-list inside_access_out permit ip any any
and you should be good to go.
Will the Pix translate the address/mask to all hosts on that network given the mask of 255.255.255.255?
That mask is for one host only.
Perfect! I put this config in and it worked great. I did however, following the other posts change the netmask from 255.255.255.255 to 255.255.255.0.
Thanks!
