10-01-2003 03:12 PM - edited 03-02-2019 10:43 AM
I'm trying to set a policy based route so that specific source addresses have a different next hop.
Here is the relevant config lines:
access-list 199 permit ip 10.1.40.0 0.0.0.255 any
route-map Internap permit 10
match ip address 199
set ip next-hop 10.100.10.1
I need to apply this route map to a routed VLAN interface but the command isn't valid. Any ideas?
--Patrick
10-01-2003 04:56 PM
use the ip policy' command on the interface
10-01-2003 05:16 PM
I could be wrong but you have to be running the EMI image for PBR to work on the 3550
10-01-2003 06:11 PM
Perfect SMI does not support PBR.
PBR requires EMI
http://www.cisco.com/en/US/products/hw/switches/ps646/products_qanda_item09186a00800913d3.shtml
10-01-2003 06:40 PM
I do have EMI code running on this switch.
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(11)EA1, RELEASE SOFTWARE (fc1)
--Patrick
10-01-2003 11:22 PM
your IOS is EMI (i5 in the file name means EMI, i9 means SMI).
BUT you need the latest IOS 12.1(14)EA1a.
PBR should be supported in it, see http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12114ea1/3550scg/swiprout.htm#1260543.
Milan
10-02-2003 10:01 PM
Okay. I just upgraded my switch to 12.1(14)EA1a. The 'ip policy route-map {name}' command now exists but will not take. When the command is entered, there is no error. When I do a show run, it isn't there. I'm trying to use this on a routed vlan interface. Is this not a valid interface type?
Patrick
10-02-2003 10:33 PM
the configuration guide (http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12114ea1/3550scg/swiprout.htm#1260543)
says:
"You can enable PBR on a routed port, an SVI, or an EtherChannel port channel in Layer 3 mode. "
So I'd open a TAC case and report the bug.
Milan
10-01-2003 06:38 PM
I tried that. It isn't a valid command.
Any more ideas?
Patrick
10-01-2003 09:04 PM
I believe PBR is supported from IOS version 12.1(13)EA1. It is one of the new features in this release:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12113ea1/ol366401.htm#89520
Hope that helps.
