How to configure my PC as a TFTP server
Oct 2nd, 2003
Hi all,
I got an issue, I wanna make my PC as a TFTP server to upgrade IOS on my routers. I would like to know how do I do it.I need some sort of TFTP client S/W or what.
Abdul
Overall Rating: 5 (2 ratings)
mrarahman Thu, 10/02/2003 - 05:53
Hi BB,
Thanks for the link.I have downloaded the S/W but still wondering how to use it,as we configure TFTP-SERVER on the router and the router PICKS up the file from the specified TFTP-SERVER. But how will it work using this tool. Its my first Exp with TFTP-servers ;-)
MAR
thisisshanky Thu, 10/02/2003 - 10:07
Place the IOS image file in the default TFTP directory ( you can find this from TFTP server -> Options or Preferences menu (usually) )
Now you also need to hook the server and router on the same lan (it could be in diff lan too-> just make sure they can reach each other).
Use the command : "copy tftp flash" and hit the return key. Router prompts u with the ip address of server, and the filename. Enter these information and hit the enter key, and it will upgrade the IOS for you.
http://www.cisco.com/warp/public/130/sw_upgrade_proc_ram.shtml
pavlosd Thu, 10/02/2003 - 05:45
My favorite option is the "Klever Internet Nothings - PumpKIN". It is very good and user friendly.
It even gives you a pop up warning when trying to download a tftp reporting which machine is requesting the file and what file is requested.
Also reports the percentage download status and time remaining.
Home Page: http://www.klever.net/kin/pumpkin.html
Software Download Link: http://www.klever.net/kin/canned/PumpKIN.exe
Regards.
For Syslog I prefer the kiwi syslog deamon
Home Page: http://www.kiwisyslog.com/index.htm
