Warning message
DHCP Stateful Caching
Oct 2nd, 2003
Guys, Have a very simple DHCP config for our network lab so all our test PCs can source addresses.
Config on Router10
ip dhcp excluded-address 10.10.10.1 10.10.10.99
ip dhcp excluded-address 10.10.10.200 10.10.10.255
ip dhcp pool 10net
network 10.10.10.0 255.255.255.0
domain-name testlabuk.com
dns-server 10.10.20.1
default-router 10.10.10.10
interface Ethernet0
ip address 10.10.10.10 255.255.255.0
So, two questions.
If i switch the route off, all my bindings disapear and what happens if I want to add another router to my LAN with an HSRP addr ? one router would assign all adresses, wot about failover?
Is there anything like MSDP for DHCP?
I know, just put in a real DHCP server I hear you say :))
Many thx,
Ken
didyap Wed, 10/08/2003 - 12:20
  • Silver, 250 points or more
Using HSRP only one router will be active at one point of time. HSRP uses a virtual ip address which is used by both the active and standy routers, so there will be no problem at the time of failover.
The ip helper-address can be used to point the devices in the LAN to the DHCP server. There are no known probelms between HSRP and DHCP.
