After a reload the rsa key for SSH is deleted...?
Oct 3rd, 2003
I try to use ssh remote connect to a 2950 Switch (IOS:c2950-i6k2l2q4-mz.121-14.EA1a.bin)
Configuration Preperation for SSH:
(config) hostname hostname
(config) ip domain-name domainname
(config) crypto key generate rsa 1024
(config) ip ssh authentication-retries 2
(config) ip ssh time-out 60
(config-line) transport input telnet ssh
After I reload the Switch, I can not use ssh anymore. I check the Rsa key, it's not there. If I generate the RSA Key again (crypto key generate rsa 1024) it works?
How can I save this RSA-Key after a reload?
Thanks for any reply.
Urs
SteveGodfrey Fri, 10/03/2003 - 05:26
I had the same problem on the PIX, turns out you need to save the RSA key seperately. A wr net won't save the key - on a PIX anyway.
The PIX command is CA SAVE ALL
Steve
