Warning message
TCP Experts - help (tcp source port)
Oct 6th, 2003
hello all,
v.quick one.
When a host initiates a TCP connection, does it always use a source port of GT 1023. Are there applications that could init a connection with a source port below 1023 in the reseved range?
Many thx indeed.
d-garnett Tue, 10/07/2003 - 14:21
in normal network operation it should
applications that "initiate" a session with a src port below 1023 are typically running a service on a PC or Server that has been hacked and "rooted"
thats why it is always good security practice to block outgoing TCP pkts (with the SYNchronization flag set) with src port below 1023.
TCP pkts with ONLY the combinations of SYN-ACK, ACK, PSH ACK, RST, FIN, and FIN-ACK's, should be ok though to let out under 1023 if you have servers on the inside of your network. These usually denote normal network operation (through traffic).
Don Garnett
