PIX 501 Configuration
Oct 7th, 2003
I am having an incredible amount of trouble getting my PIX 501 configured. I can get up on the net with it but when anyone from outside tries to access my webserver they get the first page then every subsequent page times out.
I have also setup an alias for internal users to be able to access page but the does not work either.. I have attached the config can anyone help me out?
Thank you in adavance for any help,
: Written by enable_15 at 04:46:12.946 UTC Wed Sep 24 2003
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password
passwd
hostname
domain-name
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 100 permit icmp any any echo-reply
access-list 100 permit icmp any any time-exceeded
access-list 100 permit icmp any any unreachable
access-list 100 permit tcp any host 209.xx.124.100 eq smtp
access-list 100 permit tcp any host 209.xx.124.100 eq ftp
access-list 100 permit tcp any host 209.xx.124.100 eq www
pager lines 24
logging on
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 209.xx.124.101 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.2 255.255.255.255 inside
pdm location 192.168.1.13 255.255.255.255 inside
pdm location 192.168.1.101 255.255.255.255 inside
pdm location 192.168.1.100 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 209.xx.124.102-209.xx.124.108
global (outside) 1 interface
global (outside) 1 209.xx.124.109
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 209.xx.124.100 192.168.1.13 netmask 255.255.255.255 0 0
access-group 100 in interface outside
route outside 0.0.0.0 0.0.0.0 209.xx.124.97 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet 192.168.1.2 255.255.255.255 inside
telnet 192.168.1.100 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.1.100-192.168.1.131 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxxxxxxxx
gfullage Tue, 10/07/2003 - 17:11
  • Cisco Employee,
Difficult to say what's going on. Do you redirect the user to a https page after the initial page? If so then you'd need the following:
access-list 100 permit tcp any host 209.xx.124.100 eq https
Other than that, enable syslogging in the PIX and then recreate the problem, the syslog messages will tell you what's going on:
logging on
logging buffer debug
sho log
Also I don't see the alias command you mention. Add the dns option to your static command and it should work properly, the alias command has been deprecated.
nalleyp Wed, 10/08/2003 - 08:05
No I do not have a redirect setup to an https:// site.
What is the syntax for the dns addition.. I have looked but all I see is the alias option...
Does the rest of the config look ok?
Thanks for your help,
