Warning message
Associations between AP's
Oct 7th, 2003
I currently have multiple 1200 series AP's. For some reason I cannot see any other AP's except the AP I am currently on in the association table. Also when trying to puch config to other ap's I fall into an INACTIVE state.
kmarrero Mon, 10/13/2003 - 06:36
  • Bronze, 100 points or more
Check the APs association table and make sure that it sees the other two APs. If it does not, then you may need to reconfigure the APs as possibly the configuration could be stuck or corrupted. There could as well be interference or firmware issues. Check your firmware to see if you are on the latest build.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
