Warning message
Unity license
Oct 7th, 2003
How to retrieve the license key info installed in cisco unity 3.1 (5) ?
I don't want to check the features using the key dump utility.
Any help appreciated.
Senthil
Ginger Dillon Tue, 10/07/2003 - 17:44
  • Blue, 1500 points or more
Hi -
You can use the Unity SA and go to Licensing, fourth hyperlink in the System Configuration section. It will give you the license counts and features. The serial number is your dongle key. These two screens provide much of the same info as does the key dump utility.
Sincerely, Ginger
