Warning message
JASON NIELSEN Tue, 10/07/2003 - 15:06
These would route via a centrex line(FXO Gateway).
You would have to build the Route Group and Route List before the Route Pattern is added.
Route Pattern
9.11
set partition
set Gateway/route List
Route this pattern
Provide Outside Dial Tone and Urgent Priority
Calling Party Presentation Default
Prefix Digits(Outgoing Calls)9-This adds the 9 in front of 911(User dials just 911)
Or
9.911
set partition
Route this pattern
Check Provide Outside Dial Tone and Urgent Priority.
Discard Digits none(here the user dials 9911)
Hope this helps
CCampbell_2 Tue, 10/07/2003 - 15:06
Just add 911 as a route pattern. It will work. The @ wildcard is something like [2-9]XX[2-9]XXXXXX, [2-9]11, & 01 1 3[0-469]!. I think it includes other patterns as well, but as you can see it will not conflict as there is no @ match for a number starting with 11 (removing the 9 for the access code)
9911 should also just work as it will match your current 9.@ route pattern.
HTH,
Cliff
robrhodes Tue, 10/07/2003 - 15:14
Keep in mind that the @ wildcard is a macro for the North American Numbering Plan. Not everyone can, or should, use the wildcard.
CCampbell_2 Tue, 10/07/2003 - 15:25
My NANP specific response was based on the assumption that 911 does not exist outside of the NANP and the original poster must be posting from North America and could use the @ wildcard. My question was does 911 exist outside of North America, I'm not sure what this URL does to clear that up for me.
CCampbell_2 Tue, 10/07/2003 - 15:55
Not really... :^)
I was really responding to getting taken to task for assuming that the original poster was in North America. My point was if 911 doesn't exist outside of the USA then it was a reasonable assumption that he could use the @ wildcard (And IMHO, should desire to do so, but that's a different note)
The second URL tells me that NANP was designed for use in the USA, but it doesn't tell me that it's NOT in use outside of the USA. Which if it were, would make my help less useful, but I don't think it is, and therefore robrhodes should respond to my initial question with a simple "touche". Unless it is in use outside of the US, which I'd want to know about as well since it would mean I ASSumed was to much. ;^)
Cliff
robrhodes Tue, 10/07/2003 - 15:10
Create two route pattern that point to the local gateway/route list.
911 > no digit strip
9.911 > strip pre-dot
In a multi-site environment you should create a partition for each site's local 911, place the route pattern in that partition and make sure users' DNs in each site have their 911 partition in their calling search space. You need to make sure you route to the appropriate PSAP.
Jeff Garner Tue, 10/07/2003 - 16:51
Keep in Mind many of us have had problems using 911 vs. 9.911. Many users Hit 9, to get an outside line, then 1 for long distance and forget they hit a 1 or double hit the 1 and you get a 911 call. Since the phone rings after 911, the user thinks something is wrong and usually hangs up not realizing they just called 911!!! Then in about 15 minutes you will have a nice police officer greeting you...
CCampbell_2 Tue, 10/07/2003 - 17:55
Good advice. Changing our outside line access number to an 8 has cut down on our police fines. Your warning should certainly be listed somewhere as a best practice if it isn't already. Now if only we could get our building alarm to only go off when someone was really breaking in...
