Warning message
RAS route to intranet via frame relay
Oct 7th, 2003
I want to configure my Cisco 3600 router as remote access server and gateway to intranet via frame relay.
I have successful to dial in by dial up networking get the IP address, but I can net ping and accesss to intranet via frame relay. Can you help me where is the problem?
travers.stark Tue, 10/07/2003 - 21:54
Post the configs of the router(s) so that we can diagnose the problem
pandegede Wed, 10/08/2003 - 19:44
Current configuration : 3678 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname "xxxxxx"
logging buffered 4096 debugging
logging console notifications
enable secret xxxxx
enable password xxxxx
username xxx password xxxxx
ip subnet-zero
no ip domain-lookup
ip domain-name ramayana.co.id
ip name-server 172.16.1.1
call rsvp-sync
template mon
interface FastEthernet0/0
description Link To Local
ip address x.x.x.254 255.255.255.0
speed auto
full-duplex
no cdp enable
interface Serial0/0
description line
bandwidth 128
no ip address
encapsulation frame-relay
frame-relay traffic-shaping
frame-relay ip rtp header-compression
interface Serial0/0.1 point-to-point
description Link To Jakarta
bandwidth 128
ip address x.x.x.26 255.255.255.252
frame-relay interface-dlci 100
class voipovfr
interface Serial0/1
no ip address
shutdown
no fair-queue
clockrate 2000000
interface Group-Async1
ip unnumbered FastEthernet0/0
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer idle-timeout 1200
async default routing
async dynamic routing
async mode dedicated
peer default ip address pool Ramayana
ppp authentication chap
group-range 33 48
router eigrp 100
network 172.17.0.0
network 172.101.0.0
no auto-summary
ip local pool Ramayana x.x.x.155 172.17.1.160
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip pim bidir-enable
map-class frame-relay voipovfr
no frame-relay adaptive-shaping
frame-relay cir 96000
frame-relay bc 960
frame-relay be 0
frame-relay mincir 96000
frame-relay fair-queue
frame-relay fragment 160
frame-relay ip rtp priority 16384 16383 24
logging history debugging
no cdp run
snmp-server community public RW
snmp-server enable traps tty
snmp-server host x.x.x.19 public
voice-port 2/0/0
input gain -2
operation 4-wire
type 5
voice-port 2/0/1
input gain -2
operation 4-wire
type 5
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 3..
port 2/0/0
prefix 3
dial-peer voice 2 pots
port 2/0/1
prefix 3
dial-peer voice 5 voip
destination-pattern 1..
session target ipv4:172.101.1.25
dial-peer voice 6 voip
destination-pattern 2..
dial-peer voice 7 voip
destination-pattern 5..
dial-peer voice 8 voip
destination-pattern 6..
dial-peer voice 9 voip
destination-pattern 407
dial-peer voice 10 voip
destination-pattern 402
session target ipv4:172.101.1.6
dial-peer voice 11 voip
destination-pattern 403
session target ipv4:172.101.1.10
dial-peer voice 12 voip
destination-pattern 405
session target ipv4:172.101.1.14
dial-peer voice 13 voip
destination-pattern 406
session target ipv4:172.101.1.18
dial-peer voice 14 voip
destination-pattern 404
session target ipv4:172.101.1.22
line con 0
line 33 48
flush-at-activation
login local
modem InOut
transport input all
autoselect during-login
autoselect ppp
flowcontrol hardware
line aux 0
line vty 0 4
password xxxx
login
end
travers.stark Wed, 10/08/2003 - 21:59
Looks like a routing issue.
1. Can you ping the internet from the 3600?
2. Can the other router connected to the other end of the frame relay ping the dial up client??
Travers
pandegede Thu, 10/09/2003 - 19:50
yes i can
no i cann't
i can ping to 172.17.1.254 (fast eth) but i can not ping to 172.101.1.25 (serial) and 172.16.1.252 (the other router)
i also can ping the dial up client from the 3600 router
