Warning message
Failover config for Extension Mobility
Oct 7th, 2003
I have CCM3.3(3) loaded on publisher & subscriber.Extension mobility,Tomcat service is running on both servers.In IP phone services URL, I have givem publishers ip address.In Cisco Extension Mobility Logout,I have configured "True" for Login Service Enabled field in both the servers.
When I shutdown Publisher,EM is not working on all the phones.When I shutdown Subscriber,EM is not working on few phones.But EM is working on all phones when both servers are up.
Should I configure something additional to build redundancy .I want to configure subscriber as primary & Publisher as secondary for EM.
I am using 7940 IP phones.
Regds
Jagadish
I use Extension Mobilty often and this is what I would recommend testing.
Make sure that each CCM has the following services activated:
- Cisco Extension Mobility Logout
- Cisco Extended Functions
Then in the Extension Mobility URL IP Service use a DNS name that round robined IP addresses.
This should work but I haven't tested it yet.
Hopefully it is a start to something good.
Mike
dugrant Wed, 10/08/2003 - 20:10
  • Bronze, 100 points or more
This will work fine for load balancing, but for failover, your single point of failure is the publisher. When a user logs in via EM, the database needs to be updated. If the pub is down, this will fail.
So it really only makes sense to run EM on the Pub.
jagadishs Wed, 10/08/2003 - 21:34
Thanks for replying.Does this mean that we cannot build redundancy for extension mobility ie if my pub is down,users cannot login using EM through subscriber though EM service is running on both.
Regds
Jagadish
dugrant Thu, 10/09/2003 - 08:50
Thats exactly right.
jagadishs Wed, 10/08/2003 - 21:25
Hi Mike,
How exactly should I configure DNS name that round robin.As of now I have given publisher ip add.
Regds
Jagadish
joao.medeiros Thu, 10/09/2003 - 12:23
Text below from Cisco Engineer Marcos Massakawa, about TAC case of this problem with extension mobility.
The problem, as you noted, is that the "Login" and "Logout" service URLs can really only point to
one IP address. In your case, you'd probably have these set up to point to whichever server you
wanted to be the primary one for Extension Mobility. However, if that server failed, the "Login"
and "Logout" services will no longer be useable, since they point to an IP that is no longer
reachable. If you want to enable users to be able to login and logout from the backup server, you'd
have to install EM on the other server, and create a slightly different service name that would show
up on the users' phones as a valid service, such as "Login2"/"Logout2", or "Login Backup"/"Logout
Backup", etc. The service URL for these services would point to the IP of the backup server. It
seems kind of clumsy, but it's a limitation of only being able to put one IP in the service URL.
Best Regards
Joao Medeiros
spectra-ts.nl Tue, 02/09/2010 - 09:42
Alternative would be to use a 3rd party application, e.g. ALM from Spectra (find in Google). It detects if the EM service on the publisher is down at run-time and will failover to the subscriber (or any of the backup callmanagers configured in the profile).
