Warning message
Will a 4507R work in CallManager as a MGCP device or only H.323?
Oct 9th, 2003
I do not see it in the listing of gateways drop down box, so I assume that it can only be used as a H.323 device?
Brian
colin.mccrory Fri, 10/10/2003 - 05:40
Can you confirm what version of callmanager you have and also what cards are actually installed in the 4507R for voice.
brian-henry Fri, 10/10/2003 - 06:25
Yes it has the WS-X4515 Supervisor Engine IV and WS-x4604-GWY Blade in Slot 6.
If I choose the 4000 Gateway Access Module then I only get 4 slots to choose.
Thanks for any assistance that you can provide.
c-charlebois Fri, 10/10/2003 - 06:46
The 4507R itself cannot connect to anything. It require blades for anything. And the blade that allows it to function as a voice gateway is the 4000 Access Gateway Module, which must, I beleive, be configured as a MGCP device.
brian-henry Fri, 10/10/2003 - 08:21
Thanks! Its my first time dealing with a 4507R and the blades associated with it.
I love learning though, Thanks again from here it is pretty basic :)
dugrant Fri, 10/10/2003 - 09:11
  • Bronze, 100 points or more
the AGM can do H.323 as well
