Warning message
PIX 501 on a LAN
Oct 13th, 2003
I purchased the PIX 501 for my home broadband connection. Prior to installing it, I am trying to learn it at work.
I can't get ethernet0 to accept a DHCP assigned ip. Probably something simple.
Should I be using a crossover or straight through cable ?
dmunyak Mon, 10/13/2003 - 08:20
Good stuff but I still can't get connected to the LAN.
I have tried using a straight through cable and cross over. When I issue the command sho ip, the line protocol for ethernet0 is down for either cable. I know both cables are working.
I have even tried to statically assign an IP to ethernt0. still, the line protocol is down.
dmunyak Mon, 10/13/2003 - 09:02
Stupid is as stupid does !!!!!!!!
Forget the support. Thanks anyway, but It helps to look at the switch speed. I had the PIX plugged into a 100mb switch.
Everything is working
