Warning message
Fallback bridging and IP
Oct 14th, 2003
Is it possible to have fallback bridging forward IP ? I.e. can it forward ip packets if the switch has no IP address configured on its SVI/routed ports ?
carenas123 Mon, 10/20/2003 - 07:12
  • Silver, 250 points or more
As it works with the L3 interfaces on the routers when I enable bridging, I guess it should work for SVI as well, when you try "No ip address" and enable bridge-group on it. Did you try? What was the result?
