Warning message
DSL is down but router doesn't agree...
Oct 15th, 2003
Hi, i've some troubles with my 827, when line goes down, it does not change his state: atm is up protocol is up, so the dialer and virtual access. This continues until i manually sh the atm0 and re-up it. Any way to make this automatic?
Here is my config (always under costruction..):
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 827
enable secret xxxxxxxx
no ip subnet-zero
no ip source-route
no ip domain-lookup
ip dhcp excluded-address 10.0.0.1 10.0.0.3
ip dhcp pool lan
network 10.0.0.0 255.0.0.0
default-router 10.0.0.1
dns-server x.x.x.100 195.210.92.100
interface Ethernet0
ip address 10.0.0.1 255.0.0.0
no ip directed-broadcast
ip nat inside
no ip route-cache
no ip mroute-cache
no cdp enable
hold-queue 4096 in
hold-queue 4096 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
bundle-enable
hold-queue 224 in
interface Dialer1
bandwidth 300
ip address negotiated
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
no keepalive
dialer pool 1
dialer idle-timeout 30
dialer wait-for-carrier-time 60
dialer-group 1
fair-queue 64 64 0
no cdp enable
ppp pap sent-username +++ password 7 +++
hold-queue 64 out
ip nat translation tcp-timeout 3600
ip nat translation udp-timeout 150
ip nat inside source list 100 interface Dialer1 overload
ip nat inside source static tcp 10.0.0.3 5900 interface Dialer1 5900
ip nat inside source static tcp 10.0.0.3 4662 interface Dialer1 4662
ip nat inside source static udp 10.0.0.3 4662 interface Dialer1 4662
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 100 permit ip 10.0.0.0 0.255.255.255 any
access-list 101 permit tcp 10.0.0.0 0.255.255.255 any eq ftp
access-list 101 permit tcp 10.0.0.0 0.255.255.255 any eq pop3
access-list 101 permit tcp 10.0.0.0 0.255.255.255 any eq smtp
access-list 101 permit tcp 10.0.0.0 0.255.255.255 any eq www
access-list 101 permit tcp 10.0.0.0 0.255.255.255 host x.x.92.100 eq domain
access-list 101 permit tcp 10.0.0.0 0.255.255.255 host x.x.91.0 eq domain
access-list 101 deny icmp any any
dialer-list 1 protocol ip list 101
no cdp run
line con 0
transport input none
stopbits 1
speed 115200
line vty 0 4
password +++
login
scheduler max-task-time 5000
end
I've also not solved my problem with DDR -> http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.eea1ca2 if someone is interested :)
Tks in advance for every replies.
Bye.
Georg Pauwen Wed, 10/15/2003 - 04:14
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
you might want to configure keepalives on your atm and your dialer interfaces.
GP
travis-dennis_2 Wed, 10/15/2003 - 05:00
  • Gold, 750 points or more
I had a similar problem before that was only correctable by an IOS upgrade to a newer image.
