Warning message
performed a 'clear cache' on CE-560, now 'sh stat...' no longer shows stats
Oct 16th, 2003
The CFS volume on our CE was full. I plan on adjusting the volume sizes in the near future, until then, I performed a 'clear cache' and a 'cfs clear' to free things up.
Now the CE admin webpage no longer shows stats under the Reporting link--performing a 'sh stat http usage' from the console results in the following error:
'stat/cache/http/usage/cpu/sum not found'
Do I need to restart the CE to start gathering stats again?
Gilles Dufour Fri, 10/17/2003 - 04:08
  • Cisco Employee,
probably the 'cfs clear' command erased the cfs file containing the stat.
You may have to reboot.
Try just clearing the cache next time.
Gilles.
dsiwa Fri, 10/17/2003 - 04:53
Actually, I performed a 'clear cache' first. After a day or two and not seeing any disk stats (wanted to see how much was freed up), I tried a 'cfs clear' as well. Anyhow, will try rebooting.
