Warning message
Do not work Network Show Command in Ciscoworks2000
Answered Question
Oct 16th, 2003
When I do Resource Manager Essential>Configuration Management> Network Show Command> and try to submit a show command (i.e. show cdp...)on any device the application shows this message:
Report for 10.1.1.1
Error: PGM_NM=Configuration Archive:6787:TYPE=unassigned message file:Failed to execute commands for device:10.1.1.1
Probable cause:PGM_NM=Configuration Archive:6787:TYPE=unassigned message file:Failed to send command to remote host:Did not get device prompt
Recommended action:check connection to remote host
And all device are working fine and snmp community is fine too and I cand see device in others CiscoWorks options (i.e. syslogs, campus)
Cisco Works2000, RME3.3,on a Windows2000 server
Windston
Correct Answer by glen.grant about 13 years 10 months ago
Almost sounds like you have incorrect telnet passwords configured in your archive , I would check those as it uses a telnet session to do these commands .
Overall Rating: 5 (1 ratings)
Correct Answer
glen.grant Mon, 10/20/2003 - 07:19
  • Purple, 4500 points or more
