Warning message
Connection entry can't be clear over connection idle timeout in PIX !!
Oct 16th, 2003
I am sufferring a problem about the connection can't be clear from PIX connection table over the connection idle timeout so that the new connection can't be established while the entries in connection table is over the limitation of PIX capacity .(even though the actual connection in entry has been closed long time ago) . Now , the only way I can do is to clear the connection table by manual command .
Somebody can tell me what the problem is likely to be ?
nkhawaja Thu, 10/16/2003 - 20:21
  • Cisco Employee,
This is a bug we have encountered in PIX 6.2 code
The id is CSCdy58717. Please update the code if this is the case.
Nadeem Khawaja
