IDS 4210 CPU Upgrade?
rwassom Mon, 10/20/2003 - 08:57
Cisco Systems does not support processor upgrades for any of its IDS appliances.
kleem Tue, 10/21/2003 - 10:41
  • Cisco Employee,
No, the CPU cannot be upgraded. Cisco has replaced the 4210 model with the 4215, which is also targetted towards lower bandwidth networks, but provides a little more processor power. You can upgrade the RAM in the 4210 to 512 MB (in fact it is required to run the CIDS 4.1(1) and later relases).
klwiley Tue, 10/21/2003 - 11:37
  • Cisco Employee,
You can get performance metrics from the sensor using the show interface command. It will provide you with most of the information you have requested. Also from IDM you can request statistics from the monitoring page.
KLW
