Warning message
MCS 7835 Call Manager no disk space
Oct 21st, 2003
We have a MCS 7835 server with a 18.2Gbyte drive. It's close to running out of disk space. There is a file that is 3Gbytes in size called CDR.DMP and it's on the C:\ root directory and gets modified when the backup takes place. On another Call Manager it's in C:\sti\Backup\CM\callmanagername\ directory which I think is the default location.
I want to change the location of where this file gets written, eg to a network drive, but don't know where you specifiy the location. Does anyone know?
pbarman Tue, 10/21/2003 - 04:53
  • Silver, 250 points or more
The CDR.dmp will most likely be written on the local machine itself, and if it keeps growing in size with each backup, there is a bug for this.
CSCdv44292 Bug Details
SYMPTOMS: CallManager available hard drive space diminishing over time
CONDITIONS: Locating the files CCM030x.DMP and CDR.DMP in particular will yield
dramatically growing size over time.
WORKAROUND: If hard drive space is at a premium, the CDR.DMP and CCM030x.DMP files
may be removed once the MCS.TAR / MCS.STI file has been physically backed up and verified.
scoe Wed, 10/22/2003 - 00:59
Thanks, I already found that. But if you delete these files they just get created the same size the next time the backup is run. What I want to do is change the location where it gets written to a network drive. Do you know how I would do that?
d.haeni Wed, 10/22/2003 - 06:44
In case you don't need a backup of the Call Detail Records (CDRs), you should disable it.
Right-click the backup tool -> configure settings -> uncheck the "include Database Option" (its within the CDR Database option on the CallManager tab)
The CDR.dmp creation will then be skipped during the backup process
/David
dugrant Wed, 10/22/2003 - 09:25
  • Bronze, 100 points or more
Also, you should limit the number of CDR records you allow to be saved. Set this under Service Parameters -> DBL -> Max CDR Records
