Warning message
Cisco LEAP extensions in Centrino integrated wireless cards
Oct 21st, 2003
I downloaded the current drivers for the wireless NIC from Dell. I'm using the configuration GUI that comes with it. I'm not getting very far when I try to connect to the AP.
I am wondering if I have to use the Cisco Client to configure the NIC? Or is the GUI that comes with the laptop (Intel(R)ProSet) the one to use?
Kim
derwin Sun, 10/26/2003 - 20:29
  • Cisco Employee,
Hi Kim,
Does the GUI that you have the option to enable Cisco LEAP and configure it ? If so that should be ok to use.
The Cisco ACU is only designed to work with a Cisco card.
If you think you have it configured correctly and it is not working then run the EAP debugs/diags on the AP and see where it is getting to in the process
David
kimlong Tue, 10/28/2003 - 06:34
Thanks for the input. After enabling/disabling various options, and contacting Dell, we came to the conclusion that it won't work.
Even though the Dell website claims it is interoperable, the wireless tech support person I spoke to when I opened a case said, "We just tell people it doesn't support LEAP because it doesn't work".
So, the only way I could get it to work was to disable MIC and "Cisco" on the AP Security Settings/VLAN and leave them at
none. On the client side, I enabled all the Cisco extensions, and included a login id and password.
I could see the authentication process on our ACS working and the client would be associated and authenticated on the AP.
Kim
