Warning message
WCCP L2-redirection feature support
Oct 21st, 2003
I've read that the l2-redirect feature is only supported on the Cat6500 and the 7600 router. Nevertheless, if I use the feature navigator tool I’m able to find IOS versions that supposedly support the l2-redirect feature for the 3745 or the 7204 router.
Using one of those IOS images and configuring WCCP with l2 redirection I still see, in the output of the show wccp services detail command, the GRE tunnel as the negotiated forwarding method.
Can I really use l2-redirect with the 3745 or the 7204?
Thanks in advance.
Ricardo
