Warning message
Grouping multiple ds0's from multiple T1 trunk
Oct 22nd, 2003
  • Silver, 250 points or more
AS5400-HPX and multiple TDM carriers entering my VoIP network via CT3. I know that using trunk grouping feature I can group trunks, ie, full T1's, and assign the trunk group to dial-peers and do whole lot of stuff.
What I am looking for is, if there is a way to group say 5- ds0 from say 10- T1's together into a group, and use that group into a dial-peer?
Partha
ketpatel Mon, 10/27/2003 - 11:54
  • Cisco Employee,
I dont think this is possible with PRI circuit but if you have CAS circuit I believe you can configure in following manner and have single ds0 picked out from a full T1. Please check the example attaced below. In the case below I have ds0 13 singled out from 2 T1's and both ds0 is assigned a single trunk group ID cisco#1
Hope that helps..
ketan
controller T1 2/2
framing esf
linecode b8zs
ds0-group 0 timeslots 1-12 type e&m-fgb
ds0-group 1 timeslots 13 type e&m-fgb
ds0-group 2 timeslots 14-24 type e&m-fgd
cas-custom 0
trunk-group MCI
cas-custom 1
trunk-group cisco#1
cas-custom 2
trunk-group AT&T
controller T1 2/3
shutdown
framing esf
linecode ami
cas-custom 0
trunk-group MCI
cas-custom 1
trunk-group cisco#1
cas-custom 2
trunk-group AT&T
