STP Diameter
Oct 27th, 2003
Hi all,
my topologie :
A1--D1-\
\/ | \------B1---D5--A5
A2--D2-\ / | /\
\--/---B2---D6--A6
A3--D3---/ /
A4--D4----/
Note:
A:accès switch (5509/CatOS 5.1(1))
D:distribution switch (6509/CatOS 7.4(3))
B: Backbone switch (6509/CatOS 7.4(3))
Can you tell me if the STP diameter is for A1 to A4 = A1-D1-B1-D5-A5-D6-B2-D4-A4
I can't use PVSTP+ because i have a 5500 and CatOs 7.4(3) on 6500, but i need PerVlan STP.
If you have any suggestion, tell me.
Fab
ciscopl Mon, 10/27/2003 - 07:16
'cuse
It's not easy to draw with characters when editing characters is different to viewing characters :)
My topologie :
A1 and A2 is attach to D1 and D2
D1 is attach to B1 and D2
D2 is attach to B2 and D1
B1 is attach to D5 and B2
B2 is attach to D6 and B1
etc...
Remplace dot by space in Arial:
A1--D1---B1---D5--A5
A2--D2---B2---D6--A6
petr.stepan Mon, 10/27/2003 - 08:11
If all are bridges (Layer 2) and you consider more than one point of failure, than what about path:
A1-D1-A2-D2-B2-D6-A6-D5-B1-D3-A3-D4-A4 = diameter 13
note that IEEE STP considers maximum diameter 7
you should probably try to cut it somewhere using layer 3 device(s)
see http://www.cisco.com/warp/public/473/122.html#topic6
br
ps
