Warning message
BRI Backup interface question
Answered Question
Oct 29th, 2003
I am confused about the way a backup interface can be tested. I have come across a testing mechanism whereby the backup interface is removed as a means of testing whether or not it works.
The configuration is as follows:
router01(config)#int se0.3
router01(config-subif)#no backup int bri2
router01(config-subif)#^Z
Followed by:
#sh isdn stat
ISDN BRI2 interface
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
1 Active Layer 3 Call(s)
Activated dsl 2 CCBs = 1
And finally:
#sh isdn active
Out XXXXXXXXXXXX Active(72) router02 118
I realise this may appear obvious to some, but I would appreciate it if it could be explained.
Cheers.
Correct Answer by bwilmoth about 13 years 9 months ago
I think if you have configured the route, that will make the ISDN interface to dial, even though the backup interface is removed.
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a0080093c6d.shtml
Overall Rating: 5 (1 ratings)
sanilsadasivan Tue, 12/02/2003 - 20:48
I think u have to give the backup delay command also along with the backup interface command to activatite the primary line. the bri interface wouldnt know when to disconnect .otherwise u have to manually clear the interface and then try
sanil
