Warning message
Frame-Relay cannot receive advertisement
Dear Friends,
I have a frame-relay small network with a star topology. Core router is a 3640 and 7 branches use 1750.
Core router has 7 subinterfaces point-to-point configured in one an interface.
5 branches have subinterfaces in their interface and 2 use the interface without explicit subinterface.
Routing alghorithm is RIP 2, no special configuration is in place, mostly use default, including the reverse ARP.
The problem is: core router is not receiving branches routers advertisements. But each branch receives advertisements from core router.
I posted this question before, receiving two advices. First was "use broadcast option" and second "neighbor option".
I tried both but things did not change.
I would like to get some help for this.
Thanks, Paulo
Overall Rating: 3 (3 ratings)
Harold Ritter Wed, 10/29/2003 - 08:00
  • Cisco Employee,
Paulo,
Could you include the config of one of the remote sites.
Ok. It is one sample config, from branch router:
version 12.1
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname XXX-XX-ROT-002
no logging console
enable secret xxxxxxxx
enable password xxxxx
memory-size iomem 25
ip subnet-zero
no ip finger
no ip domain-lookup
interface Serial0
description Link para Concentrador
no ip address
encapsulation frame-relay ietf
frame-relay lmi-type ansi
interface serial0.1 point-to-point
ip address 192.168.110.2 255.255.255.252
frame-relay interface-dlci 16
no ip directed-broadcast
no cdp enable
no fair-queue
interface FastEthernet0
ip address 192.168.10.1 255.255.255.0
speed auto
router rip
version 2
network 192.168.10.0
network 192.168.110.0
no auto-summary
ip classless
no ip http server
line con 0
exec-timeout 0 0
password xxxx
login
transport input none line aux 0
password xxxxx
login
line vty 0 4
password xxxx
login
end
Paulo
ruwhite Thu, 10/30/2003 - 08:32
  • Gold, 750 points or more
Is the hub configured as point-to-point subinterfaces, or as a single multipoint interface? It should be configured as a set of point-to-point subinterfaces, the way you have your remotes configured.
Russ.W
ruwhite Thu, 10/30/2003 - 17:42
Can you ping 224.0.0.9? If the remotes respond, then there's a problem on the RIP side, most likely. If they don't, then multicast isn't working.
Russ.W
mark-obrien Wed, 10/29/2003 - 10:50
  • Bronze, 100 points or more
Paulo,
Can the core router ping the branch routers over frame relay, and vice versa?
Mark
Yes, as I put static routes on the core, to circumvent this problem, everything is ok.
I can ping, data flows, all the system is working.
The only thing is that I cannot receive branches routers advertisements on the core.
In the past, we had this network running, in the same topology, with dedicated lines and Rip v2. At that time everything was ok. As we changed to frame-relay, we observed that the core stopped receiving branches routes.
Paulo
Georg Pauwen Wed, 10/29/2003 - 12:57
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
Hello Paulo,
I am not sure what the config of your hub router looks like, but you might want to check if split-horizon is disabled. Try to explicitly disable it with no ip split-horizon command.
Georg
Harold Ritter Thu, 10/30/2003 - 12:04
  • Cisco Employee,
split horizon would only prevent the hub from propagating the updates from one spoke to another.
Can we have a "sh ip prot" on one of the spokes and the hub.
deilert Thu, 10/30/2003 - 12:57
  • Silver, 250 points or more
It appears that broadcast / multicast is broken in the FR could , Is this FR over MPLS or straight FR ?
If straight FR then try a neighbor statement form the hub sites under router rip
router rip
neighbor 192.168.110.2
ruwhite Fri, 10/31/2003 - 04:31
The reason it doesn't work is that these are point-to-point subinterfaces, which means they are broadcast capable anyway. The broadcast keyword only has an impact on point-to-multipoint interfaces.
Russ.W
We can see below sh ip prot for Core and one Branch.
Static routes, I have put to circumvent the problem, are listed.
CORE-ROT-001# sh ip prot
Routing Protocol is "rip"
Sending updates every 30 seconds, next due in 11 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Outgoing update filter list for all interfaces is
Incoming update filter list for all interfaces is
Redistributing: rip
Neighbor(s):
192.168.102.2
192.168.110.2
Default version control: send version 2, receive version 2
Interface Send Recv Triggered RIP Key-chain
FastEthernet0/0 2 2
Serial0/0.1 2 2
Serial0/0.2 2 2
Serial0/0.3 2 2
Serial0/0.4 2 2
Serial0/0.5 2 2
Serial0/0.6 2 2
Serial0/0.7 2 2
FastEthernet0/1 2 2
Automatic network summarization is not in effect
Routing for Networks:
192.168.0.0
192.168.1.0
192.168.102.0
192.168.103.0
192.168.104.0
192.168.105.0
192.168.107.0
192.168.109.0
192.168.110.0
Routing Information Sources:
Gateway Distance Last Update
192.168.107.2 120 00:00:27
192.168.104.2 120 00:00:04
192.168.105.2 120 00:00:17
192.168.110.2 120 00:00:12
192.168.109.2 120 3w0d
192.168.102.2 120 3w3d
192.168.103.2 120 3w0d
Distance: (default is 120)
BRANCH10-ROT-002#sh ip prot
Sending updates every 30 seconds, next due in 24 seconds
Redistributing: rip
Neighbor(s):
192.168.110.1
FastEthernet0 2 2
Serial0.1 2 2
192.168.10.0
192.168.110.0
192.168.110.1 120 00:00:16
deilert Fri, 10/31/2003 - 06:30
Can you paste in the core config , it looks like you are only advertising 192.168.0.0 192.168.1.0 , is no auto-summary configured ?
Configuration of the CORE is :
version 12.0
hostname CORE-ROT-001
no logging console
enable secret 5 xxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxx
ip subnet-zero
no ip source-route
no ip domain-lookup
ip inspect name entrada2 tcp
ip inspect name entrada2 smtp
ip inspect name saida2 tcp
ip inspect name saida2 http
ip inspect name saida2 smtp
ip inspect name saida2 ftp
ip inspect name saida2 udp
ip audit notify log
ip audit po max-events 100
ip audit smtp spam 30
ip audit name EXTERMINATOR info action alarm
ip audit name EXTERMINATOR attack action alarm drop reset
interface FastEthernet0/0
description Rede Local Matriz
duplex auto
speed auto
no cdp enable
interface Serial0/0
description MAIN INTERFACE (HUB)
no ip address
encapsulation frame-relay IETF
interface Serial0/0.1 point-to-point
description Link Frame w/ BRANCH 1
ip address 192.168.102.1 255.255.255.252
no cdp enable
frame-relay interface-dlci 23
interface Serial0/0.2 point-to-point
description Link Frame w/ BRANCH 2
ip address 192.168.103.1 255.255.255.252
no cdp enable
frame-relay interface-dlci 18
interface Serial0/0.3 point-to-point
description Link Frame w/ BRANCH 3
ip address 192.168.110.1 255.255.255.252
no cdp enable
frame-relay interface-dlci 19
interface Serial0/0.4 point-to-point
description Link Frame w/ BRANCH 4
ip address 192.168.107.1 255.255.255.252
no cdp enable
frame-relay interface-dlci 20
interface Serial0/0.5 point-to-point
description Link Frame w/ BRANCH 5
ip address 192.168.105.1 255.255.255.252
no cdp enable
frame-relay interface-dlci 21
interface Serial0/0.6 point-to-point
description Link Frame w/ BRANCH 6
ip address 192.168.104.1 255.255.255.252
no cdp enable
frame-relay interface-dlci 17
interface Serial0/0.7 point-to-point
ddescription Link Frame w/ BRANCH 7
ip address 192.168.109.1 255.255.255.252
no cdp enable
frame-relay interface-dlci 22
interface FastEthernet0/1
description DMZ NETWORK
ip address 192.168.0.1 255.255.255.252
ip inspect entrada2 in
ip inspect saida2 out
ip audit EXTERMINATOR in
duplex auto
speed auto
no cdp enable
interface Serial0/1
description Rede Botafogo II
no ip address
no cdp enable
interface Serial0/2
no ip address
no cdp enable
router rip
version 2
network 192.168.0.0
network 192.168.1.0
network 192.168.102.0
network 192.168.103.0
network 192.168.104.0
network 192.168.105.0
network 192.168.107.0
network 192.168.109.0
neighbor 192.168.102.2
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.2
!static routes to circumvents Rip advertisement problem
ip route 192.168.2.0 255.255.255.0 192.168.102.2
ip route 192.168.3.0 255.255.255.0 192.168.103.2
ip route 192.168.4.0 255.255.255.0 192.168.104.2
ip route 192.168.5.0 255.255.255.0 192.168.105.2
ip route 192.168.7.0 255.255.255.0 192.168.107.2
ip route 192.168.9.0 255.255.255.0 192.168.109.2
ip route 192.168.10.0 255.255.255.0 192.168.110.2
no ip http server
logging 192.168.1.26
access-list 131 deny ip 10.0.0.0 0.255.255.255 any log
access-list 131 deny ip 172.16.0.0 0.15.255.255 any log
access-list 131 deny ip 127.0.0.0 0.255.255.255 any log
access-list 131 permit tcp host 192.168.0.2 gt 1023 host 192.168.1.24 eq smtp
access-list 131 permit tcp host 192.168.0.2 gt 1023 host 192.168.1.25 eq smtp
access-list 131 permit tcp host 192.168.0.2 gt 1023 any eq 261
access-list 131 deny ip any any log
access-list 132 permit udp host 192.168.1.23 eq domain host 192.168.254.2 eq domain
access-list 132 permit udp host 192.168.1.23 gt 1023 host 192.168.254.2 eq domain
access-list 132 permit tcp 192.168.0.0 0.0.15.255 any log
access-list 132 deny ip any any log
no cdp run
banner motd This is a private network
Any unauthorized access will be punished under applicable laws.
line con 0
login
line aux 0
line vty 0 4
login
end
Harold Ritter Fri, 10/31/2003 - 06:48
  • Cisco Employee,
I'm sure I'm not the only one curious about what the hub router config looks like. Could you please post it. Thx.
ruwhite Fri, 10/31/2003 - 07:22
Are these the routers attached reachable through the serials interfaces?
If not, then the updates transmitted by the remote routers aren't being received by the hub router. Can you ping 224.0.0.9? You don't have authentication set up, do you?
Russ.W
rjackson Fri, 10/31/2003 - 08:07
You dont have to guess, run debug ip rip on both sides and see whats happening.
deilert Mon, 11/03/2003 - 05:32
can you paste in a sh ip route from both sides
Georg Pauwen Tue, 11/04/2003 - 03:18
    2017 WAN
Paulo,
just for curiosity, what was the answer/solution to this problem ?
GP
deilert Tue, 11/04/2003 - 05:44
Are these FE interfaces at the branches up up ?
Harold Ritter Tue, 11/04/2003 - 09:41
  • Cisco Employee,
Paulo,
By the way, I can see you 7 remote sites configured as point-to-point subinterfaces but as far as the two other remote sites that are supposedly configured under the main interface, IP is not configured under that main interface.
Sh ip route CORE/BRANCH
CORE-ROT-001#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 192.168.0.2 to network 0.0.0.0
192.168.107.0/30 is subnetted, 1 subnets
C 192.168.107.0 is directly connected, Serial0/0.4
192.168.104.0/30 is subnetted, 1 subnets
C 192.168.104.0 is directly connected, Serial0/0.6
192.168.105.0/30 is subnetted, 1 subnets
C 192.168.105.0 is directly connected, Serial0/0.5
192.168.110.0/30 is subnetted, 1 subnets
C 192.168.110.0 is directly connected, Serial0/0.3
S 192.168.9.0/24 [1/0] via 192.168.109.2
S 192.168.10.0/24 [1/0] via 192.168.110.2
192.168.109.0/30 is subnetted, 1 subnets
C 192.168.109.0 is directly connected, Serial0/0.7
S 192.168.4.0/24 [1/0] via 192.168.104.2
S 192.168.5.0/24 [1/0] via 192.168.105.2
S 192.168.7.0/24 [1/0] via 192.168.107.2
192.168.0.0/30 is subnetted, 1 subnets
C 192.168.0.0 is directly connected, FastEthernet0/1
192.168.102.0/30 is subnetted, 1 subnets
C 192.168.102.0 is directly connected, Serial0/0.1
C 192.168.1.0/24 is directly connected, FastEthernet0/0
192.168.103.0/30 is subnetted, 1 subnets
C 192.168.103.0 is directly connected, Serial0/0.2
S 192.168.2.0/24 [1/0] via 192.168.102.2
S 192.168.3.0/24 [1/0] via 192.168.103.2
S* 0.0.0.0/0 [1/0] via 192.168.0.2
CORE-ROT-001#
BRANCH-ROT-002#sh log
Syslog logging: enabled (0 messages dropped, 0 flushes, 0 overruns)
Console logging: level debugging, 1805 messages logged
Monitor logging: level debugging, 0 messages logged
Buffer logging: disabled
Trap logging: level informational, 21 message lines logged
BRANCH-ROT-002#sh ip route
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
Gateway of last resort is 192.168.110.1 to network 0.0.0.0
R 192.168.107.0 [120/1] via 192.168.110.1, 00:00:03, Serial0.1
R 192.168.104.0 [120/1] via 192.168.110.1, 00:00:03, Serial0.1
R 192.168.105.0 [120/1] via 192.168.110.1, 00:00:03, Serial0.1
C 192.168.110.0 is directly connected, Serial0.1
C 192.168.10.0/24 is directly connected, FastEthernet0
R 192.168.109.0 [120/1] via 192.168.110.1, 00:00:03, Serial0.1
R 192.168.0.0 [120/1] via 192.168.110.1, 00:00:03, Serial0.1
R 192.168.102.0 [120/1] via 192.168.110.1, 00:00:08, Serial0.1
R 192.168.1.0/24 [120/1] via 192.168.110.1, 00:00:08, Serial0.1
R 192.168.103.0 [120/1] via 192.168.110.1, 00:00:08, Serial0.1
S* 0.0.0.0/0 [1/0] via 192.168.110.1
BRANCH-ROT-002#
Paulo
Listing DEBUG IP RIP
Below is this listing. Core is receiving all routes from branches. What is happening? Core receives routes but does not use them to update RIP Route table.
2003-11-04 15:11:13 Local7.Debug 192.168.1.1 96912: 5w1d: RIP: sending v2 update to 192.168.102.2 via Serial0/0.1 (192.168.102.1)
2003-11-04 15:11:13 Local7.Debug 192.168.1.1 96913: 5w1d: RIP: build update entries
2003-11-04 15:11:13 Local7.Debug 192.168.1.1 96914: 5w1d: <009>192.168.0.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:13 Local7.Debug 192.168.1.1 96915: 5w1d: <009>192.168.1.0/24 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:13 Local7.Debug 192.168.1.1 96916: 5w1d: <009>192.168.103.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:13 Local7.Debug 192.168.1.1 96917: 5w1d: <009>192.168.104.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:13 Local7.Debug 192.168.1.1 96918: 5w1d: <009>192.168.105.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:13 Local7.Debug 192.168.1.1 96919: 5w1d: <009>192.168.107.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96920: 5w1d: <009>192.168.109.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96921: 5w1d: <009>192.168.110.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96922: 5w1d: RIP: sending v2 update to 192.168.110.2 via Serial0/0.3 (192.168.110.1)
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96923: 5w1d: RIP: build update entries
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96924: 5w1d: <009>192.168.0.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96925: 5w1d: <009>192.168.1.0/24 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96926: 5w1d: <009>192.168.102.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96927: 5w1d: <009>192.168.103.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96928: 5w1d: <009>192.168.104.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96929: 5w1d: <009>192.168.105.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96930: 5w1d: <009>192.168.107.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96931: 5w1d: <009>192.168.109.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96932: 5w1d: RIP: received v2 update from 192.168.105.2 on Serial0/0.5
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96933: 5w1d: 192.168.5.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96934: 5w1d: RIP: received v2 update from 192.168.105.2 on Serial0/0.5
2003-11-04 15:11:16 Local7.Debug 192.168.1.1 96935: 5w1d: 192.168.5.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:24 Local7.Debug 192.168.1.1 96936: 5w1d: RIP: received v2 update from 192.168.103.2 on Serial0/0.2
2003-11-04 15:11:24 Local7.Debug 192.168.1.1 96937: 5w1d: 192.168.0.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:24 Local7.Debug 192.168.1.1 96938: 5w1d: 192.168.3.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:24 Local7.Debug 192.168.1.1 96939: 5w1d: 192.168.102.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:24 Local7.Debug 192.168.1.1 96940: 5w1d: 192.168.104.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:24 Local7.Debug 192.168.1.1 96941: 5w1d: 192.168.105.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:24 Local7.Debug 192.168.1.1 96942: 5w1d: 192.168.107.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:24 Local7.Debug 192.168.1.1 96943: 5w1d: 192.168.109.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:24 Local7.Debug 192.168.1.1 96944: 5w1d: 192.168.110.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96945: 5w1d: RIP: received v2 update from 192.168.102.2 on Serial0/0.1
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96946: 5w1d: 0.0.0.0/0 via 0.0.0.0 in 1 hops
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96947: 5w1d: 192.168.0.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96948: 5w1d: 192.168.2.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96949: 5w1d: 192.168.103.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96950: 5w1d: 192.168.104.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96951: 5w1d: 192.168.105.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96952: 5w1d: 192.168.107.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96953: 5w1d: 192.168.109.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:26 Local7.Debug 192.168.1.1 96954: 5w1d: 192.168.110.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:27 Local7.Debug 192.168.1.1 96955: 5w1d: RIP: received v2 update from 192.168.102.2 on Serial0/0.1
2003-11-04 15:11:27 Local7.Debug 192.168.1.1 96956: 5w1d: 192.168.0.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:27 Local7.Debug 192.168.1.1 96957: 5w1d: 192.168.2.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:27 Local7.Debug 192.168.1.1 96958: 5w1d: 192.168.103.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:27 Local7.Debug 192.168.1.1 96959: 5w1d: 192.168.104.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:27 Local7.Debug 192.168.1.1 96960: 5w1d: 192.168.105.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:27 Local7.Debug 192.168.1.1 96961: 5w1d: 192.168.107.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:27 Local7.Debug 192.168.1.1 96962: 5w1d: 192.168.109.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:27 Local7.Debug 192.168.1.1 96963: 5w1d: 192.168.110.0/24 via 0.0.0.0 in 16 hops (inaccessible)
2003-11-04 15:11:30 Local7.Debug 192.168.1.1 96964: 5w1d: RIP: received v2 update from 192.168.107.2 on Serial0/0.4
2003-11-04 15:11:30 Local7.Debug 192.168.1.1 96965: 5w1d: 192.168.7.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:31 Local7.Debug 192.168.1.1 96966: 5w1d: RIP: received v2 update from 192.168.109.2 on Serial0/0.7
2003-11-04 15:11:31 Local7.Debug 192.168.1.1 96967: 5w1d: 192.168.9.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96968: 5w1d: RIP: received v2 update from 192.168.104.2 on Serial0/0.6
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96969: 5w1d: 0.0.0.0/0 via 0.0.0.0 in 1 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96970: 5w1d: 192.168.0.0/30 via 0.0.0.0 in 2 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96971: 5w1d: 192.168.1.0/24 via 0.0.0.0 in 2 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96972: 5w1d: 192.168.4.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96973: 5w1d: 192.168.102.0/30 via 0.0.0.0 in 2 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96974: 5w1d: 192.168.103.0/30 via 0.0.0.0 in 2 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96975: 5w1d: 192.168.104.0/30 via 0.0.0.0 in 1 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96976: 5w1d: 192.168.105.0/30 via 0.0.0.0 in 2 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96977: 5w1d: 192.168.107.0/30 via 0.0.0.0 in 2 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96978: 5w1d: 192.168.109.0/30 via 0.0.0.0 in 2 hops
2003-11-04 15:11:33 Local7.Debug 192.168.1.1 96979: 5w1d: 192.168.110.0/30 via 0.0.0.0 in 2 hops
2003-11-04 15:11:36 Local7.Debug 192.168.1.1 96980: 5w1d: RIP: received v2 update from 192.168.110.2 on Serial0/0.3
2003-11-04 15:11:36 Local7.Debug 192.168.1.1 96981: 5w1d: 192.168.10.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:36 Local7.Debug 192.168.1.1 96982: 5w1d: RIP: received v2 update from 192.168.110.2 on Serial0/0.3
2003-11-04 15:11:36 Local7.Debug 192.168.1.1 96983: 5w1d: 192.168.10.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:42 Local7.Debug 192.168.1.1 96984: 5w1d: RIP: received v2 update from 192.168.105.2 on Serial0/0.5
2003-11-04 15:11:42 Local7.Debug 192.168.1.1 96985: 5w1d: 192.168.5.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:42 Local7.Debug 192.168.1.1 96986: 5w1d: RIP: received v2 update from 192.168.105.2 on Serial0/0.5
2003-11-04 15:11:42 Local7.Debug 192.168.1.1 96987: 5w1d: 192.168.5.0/24 via 0.0.0.0 in 1 hops
2003-11-04 15:11:42 Local7.Debug 192.168.1.1 96988: 5w1d: RIP: sending v2 update to 224.0.0.9 via FastEthernet0/0 (192.168.1.1)
2003-11-04 15:11:42 Local7.Debug 192.168.1.1 96989: 5w1d: RIP: build update entries
Paulo
deilert Tue, 11/04/2003 - 10:25
it looks as if the router belives that all route networks are reachable through your defualt route , try to remove your 0.0.0.0 0.0.0.0 static on your core see if this corrects the problem
deilert Tue, 11/04/2003 - 10:28
it looks as if the router belives that all networks are reachable through your defualt route , try to remove your 0.0.0.0 0.0.0.0 static on your core see if this corrects the problem
ruwhite Tue, 11/04/2003 - 11:31
Right now there are static routes covering the same networks you are receiving updates for, so it's hard to tell. Can you look at the RIP database on the core router, and see if they are in that database? show ip rip data.
Russ.W
Last data makes easy to see what is happening.
CORE router receive a RIP v2 advertisement from each remote branch.
But, RIP router engine does not use these routes in core´s rip data base. What reason?
------------------------debug ip rip listing ------------------------------------------------------------------------------------
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152320: 5w3d: RIP: sending v2 update to 224.0.0.9 via Serial0/0.7 (192.168.109.1)
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152321: 5w3d: RIP: build update entries
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152322: 5w3d: <009>192.168.0.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152323: 5w3d: <009>192.168.1.0/24 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152324: 5w3d: <009>192.168.102.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152325: 5w3d: <009>192.168.103.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152326: 5w3d: <009>192.168.104.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152327: 5w3d: <009>192.168.105.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152328: 5w3d: <009>192.168.107.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152329: 5w3d: <009>192.168.110.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152330: 5w3d: RIP: sending v2 update to 224.0.0.9 via FastEthernet0/1 (192.168.0.1)
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152331: 5w3d: RIP: build update entries
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152332: 5w3d: <009>192.168.1.0/24 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152333: 5w3d: <009>192.168.102.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152334: 5w3d: <009>192.168.103.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:34 Local7.Debug 192.168.1.1 152335: 5w3d: <009>192.168.104.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:38 Local7.Debug 192.168.1.1 152336: 5w3d: <009>192.168.105.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:38 Local7.Debug 192.168.1.1 152337: 5w3d: <009>192.168.107.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:38 Local7.Debug 192.168.1.1 152338: 5w3d: <009>192.168.109.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:38 Local7.Debug 192.168.1.1 152339: 5w3d: <009>192.168.110.0/30 via 0.0.0.0, metric 1, tag 0
2003-11-06 17:20:40 Local7.Debug 192.168.1.1 152340: 5w3d: RIP: received v2 update from 192.168.104.2 on Serial0/0.6
2003-11-06 17:20:40 Local7.Debug 192.168.1.1 152341: 5w3d: 192.168.4.0/24 via 0.0.0.0 in 1 hops
2003-11-06 17:20:44 Local7.Debug 192.168.1.1 152342: 5w3d: RIP: received v2 update from 192.168.110.2 on Serial0/0.3
2003-11-06 17:20:44 Local7.Debug 192.168.1.1 152343: 5w3d: 192.168.10.0/24 via 0.0.0.0 in 1 hops
2003-11-06 17:20:47 Local7.Debug 192.168.1.1 152344: 5w3d: RIP: received v2 update from 192.168.109.2 on Serial0/0.7
2003-11-06 17:20:47 Local7.Debug 192.168.1.1 152345: 5w3d: 192.168.9.0/24 via 0.0.0.0 in 1 hops
2003-11-06 17:20:51 Local7.Debug 192.168.1.1 152346: 5w3d: RIP: received v2 update from 192.168.103.2 on Serial0/0.2
2003-11-06 17:20:51 Local7.Debug 192.168.1.1 152347: 5w3d: 192.168.3.0/24 via 0.0.0.0 in 1 hops
2003-11-06 17:20:54 Local7.Debug 192.168.1.1 152348: 5w3d: RIP: received v2 update from 192.168.107.2 on Serial0/0.4
2003-11-06 17:20:54 Local7.Debug 192.168.1.1 152349: 5w3d: 192.168.7.0/24 via 0.0.0.0 in 1 hops
2003-11-06 17:20:57 Local7.Debug 192.168.1.1 152350: 5w3d: RIP: received v2 update from 192.168.105.2 on Serial0/0.5
2003-11-06 17:20:57 Local7.Debug 192.168.1.1 152351: 5w3d: 192.168.5.0/24 via 0.0.0.0 in 1 hops
2003-11-06 17:21:01 Local7.Debug 192.168.1.1 152352: 5w3d: RIP: received v2 update from 192.168.102.2 on Serial0/0.1
2003-11-06 17:21:01 Local7.Debug 192.168.1.1 152353: 5w3d: 192.168.2.0/24 via 0.0.0.0 in 1 hops
-----------------------------------------------------------------------------------CORE DATA sh ip rip data --------------------------------------
CORE-ROT-001#sh ip rip data
192.168.0.0/24 auto-summary
192.168.0.0/30 directly connected, FastEthernet0/1
192.168.1.0/24 auto-summary
192.168.1.0/24 directly connected, FastEthernet0/0
192.168.102.0/24 auto-summary
192.168.102.0/30 directly connected, Serial0/0.1
192.168.103.0/24 auto-summary
192.168.103.0/30 directly connected, Serial0/0.2
192.168.104.0/24 auto-summary
192.168.104.0/30 directly connected, Serial0/0.6
192.168.105.0/24 auto-summary
192.168.105.0/30 directly connected, Serial0/0.5
192.168.107.0/24 auto-summary
192.168.107.0/30 directly connected, Serial0/0.4
192.168.109.0/24 auto-summary
192.168.109.0/30 directly connected, Serial0/0.7
192.168.110.0/24 auto-summary
192.168.110.0/30 directly connected, Serial0/0.3
CORE-ROT-001#
-------------------------------------------------------------------------CORE sh ip protocol ----------------------------------------------
CORE-ROT-001#sh ip protocol
Sending updates every 30 seconds, next due in 20 seconds
Redistributing: rip
FastEthernet0/0 2 2
Serial0/0.1 2 2
Serial0/0.2 2 2
Serial0/0.3 2 2
Serial0/0.4 2 2
Serial0/0.5 2 2
Serial0/0.6 2 2
Serial0/0.7 2 2
FastEthernet0/1 2 2
192.168.0.0
192.168.1.0
192.168.102.0
192.168.103.0
192.168.104.0
192.168.105.0
192.168.107.0
192.168.109.0
192.168.110.0
192.168.107.2 120 00:00:15
192.168.104.2 120 00:00:09
192.168.105.2 120 00:00:26
192.168.110.2 120 00:00:24
192.168.109.2 120 00:00:02
192.168.102.2 120 00:00:08
192.168.103.2 120 00:00:22
CORE-ROT-001#
------------------------------------------------------------------------------------------------------------- Paulo
