Warning message
Harold Ritter Thu, 10/30/2003 - 06:05
  • Cisco Employee,
You can use the "clear line" command if it is a telnet session that you are trying to reset. For other type of TCP sessions you can do a "show tcp brief" to list the active TCP sessions and the associated TCBs and then do a "clear tcp tcb "
Hope this help.
biao-shen Thu, 10/30/2003 - 06:36
Hi Hritter,
Thanks , Is the possible to show tcp session
pass through the router? no only start by or end to
this router.
BRs
Biao
Pavel Bykov Thu, 10/30/2003 - 07:38
  • Silver, 250 points or more
I don't know if you can RESET session that is passing through the router, but i know you can block it using the access lists.
rais Thu, 10/30/2003 - 10:40
If the router is doing NAT/PAT, clearing NAT translations will void all TCP sessions.
Thanks.
biao-shen Thu, 10/30/2003 - 16:53
Hi all,
Thanks ; ) . for the traffic pass through Cisco Router,
maybe need other tools like ACS,IDS.
BRs
Biao
prafuljaded Sun, 11/02/2003 - 07:18
You can enable ip route-cache flow on the interface to check the TCP sessions passing thru the router.Issue " show ip cache flow | i 06" where 06 is Protocol number for TCP in an IP datagram.Make sure you enable it during non-peak hours.
