Warning message
2 interfaces
Oct 30th, 2003
I have two routers, a 2620 and a 2620XM, both with WIC 1DSU T1 cards and fastethernet ports. When I configure the serial (WAN) port the ethernet port goes down and vice versa. How do I configure the routers so both interfaces are up?
Thanks in advance,
Emjay
Georg Pauwen Thu, 10/30/2003 - 12:27
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
which IOS versions are you using ? Can you post the configs of the routers ?
Georg
emjay Thu, 10/30/2003 - 12:45
The 2620:
IOS (tm) C2600 Software (C2600-I-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 07-Dec-99 02:12 by phanguye
Image text-base: 0x80008088, data-base: 0x807AAF70
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
iworx_bristol uptime is 4 hours, 39 minutes
System image file is "flash:c2600-i-mz.120-7.T"
cisco 2620 (MPC860) processor (revision 0x600) with 26624K/6144K bytes of memory
Processor board ID JAD05450P8W (4054685481)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
The 2620XM:
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(8)T10, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 30-May-03 02:45 by kellythw
Image text-base: 0x80008074, data-base: 0x80A2C2B0
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
iworx_scarboro uptime is 3 hours, 42 minutes
System image file is "flash:c2600-i-mz.122-8.T10.bin"
cisco 2620XM (MPC860P) processor (revision 0x100) with 28672K/4096K bytes of mem
ory.
Processor board ID JAE07220QFK (1227388095)
M860 processor: part number 5, mask 2
Bridging software.
16384K bytes of processor board System flash (Read/Write)
Is that what you need?
emjay Fri, 10/31/2003 - 05:56
Here's some more info:
2620:
FastEthernet0/0 is up, line protocol is up
Internet address is 192.168.128.102/24
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP Null turbo vector
IP multicast fast switching is disabled
IP multicast distributed fast switching is disabled
IP route-cache flags are None
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
Serial0/0 is down, line protocol is down
Internet address is 192.168.128.122/24
MTU is 1500 bytes
2620XM:
Internet address is 192.168.128.2/24
Address determined by non-volatile memory
MTU is 1500 bytes
Local Proxy ARP is disabled
WCCP Redirect inbound is disabled
Internet address is 192.168.128.22/24
MTU is 1500 bytes
Thanks again,
Emjay
rjackson Fri, 10/31/2003 - 07:59
  • Bronze, 100 points or more
What are you doing to configure the wic, show us the conf and what you are adding.
emjay Fri, 10/31/2003 - 08:54
Current configuration:
2620:
iworx_bristol#sh conf
Using 799 out of 29688 bytes
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname iworx_bristol
enable secret xxxxxxxx
enable password *****
ip subnet-zero
no ip routing
interface FastEthernet0/0
ip address 192.168.128.102 255.255.255.0
no ip directed-broadcast
no ip route-cache
no ip mroute-cache
speed auto
half-duplex
interface Serial0/0
ip address 192.168.128.122 255.255.255.0
encapsulation ppp
no ip route-cache
no ip mroute-cache
service-module t1 timeslots 1-24
ip classless
no ip http server
snmp-server engineID local xxxxx
snmp-server community public RO
line con 0
transport input none
line aux 0
line vty 0 4
password *****
login
end
2620XM:
iworx_scarboro#sh conf
Using 741 out of 29688 bytes
version 12.2
hostname iworx_scarboro
enable secret xxxx
ip subnet-zero
no ip routing
ip address 192.168.128.2 255.255.255.0
no ip route-cache
no ip mroute-cache
speed auto
half-duplex
interface Serial0/0
ip address 192.168.128.22 255.255.255.0
encapsulation ppp
no ip route-cache
no ip mroute-cache
fair-queue
service-module t1 clock source internal
ip classless
ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password *****
login
end
Desired configuration:
whatever is needed to extend our LAN to a WAN by locating the 2620 in a remote office while keeping the 2620XM in the local office. The two offices are linked via a point to point T1 provisioned and tested as B8ZS/ESF.
Thanks again,
Emjay
javedmma Fri, 10/31/2003 - 10:07
You are using the same network address for both the interfaces. The Interfaces should be on different networks.
emjay Fri, 10/31/2003 - 10:18
On the 2620 I'm using 192.168.128.102 for the fastethernet and 192.168.128.122 for the serial.
On the 2620XM I'm using 192.168.128.2 for the fastethernet and 192.168.128.22 for the serial.
They're all different. What needs to change? How?
Emjay
javedmma Fri, 10/31/2003 - 12:30
The network address for addresses 192.168.128.102 and 192.168.128.122 with a mask of 255.255.255.0 will be 192.168.128.0. Try to use any other network like 192.168.129.0 mask 255.255.255.0 for the serial interfaces.
kadirkocaer Mon, 11/03/2003 - 00:45
you must apply your serial connection a clock rate and specify your interface type dte/dce?
