Warning message
Hi -
To block MSN Messenger try the following:
· TCP Port 1863
· IP Range 64.4.13.0/24
So on the PIX that would equate to:
> access-list outbound deny tcp any any eq 1863
> access-list outbound deny ip any 64.4.13.0 255.255.255.0
> access-list outbound permit ip any any
> access-group outbound in interface inside
For Yahoo:
Blocking Yahoo Messenger is not as easy as blocking other pieces of software. You see, Yahoo has their servers seperated out across various IPs, and you can't just do a range block, for risk of making parts of Yahoo disappear from your users browsers. So, to block Yahoo Messenger, you must block these 2servers by DNS address, not range,
DNS names:
cs.yahoo.com
scsa.yahoo.com
Regards - Jay.
bfl1 Mon, 11/03/2003 - 06:04
This will help block several of the IM's:
AOL Instant Messenger
Prevet File Transfers:
TCP 5190
IM images TCP 4443
Disable all together
block login.oscar.aol.com on ALL ports.
MSN
Prevent File Transfers, disable incoming/outgoing TCP 6891
Prevent Audio/Video conferencing, block UDP 13324 and 13325
Prevent Applicaiton sharing block TCP 1503
Disable altogether deny access to hosts in the msgr.hotmail.com subdomain and block TCP 1863
ICQ
Prevent file transfers, block TCP 3574
Disable file sharing images, block TCP 7320
Disable ICQ completely, deny access to loign.icq.com on TCP 5190
jackson.lancast... Thu, 11/13/2003 - 07:40
You say that you need to block yahoo messenger by dns name. You imply this can be done on a PIX. If you know the secret of setting up a PIX acl based on host/domain name please let me know. We are evaluating PIX vs. Sidewinders now and this is the ONE feature the Sidewinder has over the PIX that may keep us from switching.
bfl1 Fri, 11/14/2003 - 20:30
You would nslookup the dns name and use the IP. You can't use DNS to resolve names - you can only create "host" entries with the "name" command. From a security point of view, not using dns resolution on the PIX is a good thing, IMHO.
rshedlow Thu, 11/20/2003 - 11:38
You're correct in that the PIX cannot restrict based on domain name. An alternative would be to blackhole IM domains/hosts e.g., login.oscar.aol.com, by having internal/dmz dns entries for them which direct traffic to a null0 interface somewhere.
