Error Message in ApplicationLog
Nov 4th, 2003
Hi, I get the following error in the ApplicationLog of my Publisher running 3.2.2c SP H
Source: Cisco CallManager
Category: None
Type: Error
Computer:OSTCM1
Error: RouteListExhausted - An available route not found in the indicated route list.
UNKNOWN_PARAMNAME:MediaResourceListName: RL_Cluster-OST_Hub_Local_PSTN
App ID: Cisco CallManager
Cluster ID: OSTCM1-Cluster
Node ID: 159.232.61.31
Explanation: An available route could not be found in the indicated route list.
Recommended Action: Add additional routes in the indicated route list.
This alarm indicates a network failure or device failure..
What does this message mean?How can I fix it?
Peter
trailman73 Tue, 11/04/2003 - 07:13
  • Bronze, 100 points or more
This means that ccm can't find a route pattern to match the callers number. Just curios, do you have more than 500 translation patterns pointing to a specific Gateway/Routelist? If you enable detailed tracing you can see where the call is trying to go. For instance you have a number set to go out of gateway 1 in your route pattern, but it is going out of gateway 2 or 3, sporadic?
Geoff
Erick Bergquist Tue, 11/04/2003 - 20:18
  • Silver, 250 points or more
You will also get this error if for some reason CCM can't reach the gateway address. I ran into this when a loopback interface accidentally was deleted on the gateway that h323 was previously pointed to.
pwenger Thu, 11/06/2003 - 05:52
Geoff,
thanks for the reply.There is currently just one TranslationPattern configured.This Pattern is pointing to the IVR. At the moment there are a lot of calls coming in, which are forwarded to the IVR. Could this cause this error message?
Peter
trailman73 Thu, 11/06/2003 - 08:07
do you have enough ports to handle the calls? How is Switzerland?
Geoff
