DHCP lease and ACL
Nov 5th, 2003
1)I am using the following ACL (see below) on inbound traffic via ethernet0 (which interfaces to a motorola cable modem).
2) About the same time every day, my 1721 Router "loses" it's DHCP address from the cable provider(on ethernet0).
3) The only way I can get the router to pick up the DHCP address, is to remove the ACL from ethernet0, wait until the DHCP address is picked up again, and then I have to re-apply the ACL.
4) If I don't use my ACL, the DCHP address works without a hitch.
Any suggestions?
access-list 101 permit tcp any any eq telnet
access-list 101 permit tcp any any eq ftp-data
access-list 101 permit tcp any any eq smtp
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq echo
access-list 101 permit tcp any any eq pop3
access-list 101 permit tcp any any eq 143
access-list 101 permit tcp any any eq 372
access-list 101 permit tcp any any eq 546
access-list 101 permit udp any any eq 546
access-list 101 permit tcp any any eq 547
access-list 101 permit udp any any eq 547
access-list 101 permit tcp any any eq 647
access-list 101 permit udp any any eq 647
access-list 101 permit tcp any any eq 847
access-list 101 permit udp any any eq 847
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq 873
access-list 101 permit udp any any eq 873
access-list 101 permit tcp any any eq 8383
access-list 101 permit tcp any any eq 8385
access-list 101 permit tcp any any eq 8484
access-list 101 permit tcp any any eq 9595
access-list 101 permit tcp any any eq 5631
access-list 101 permit udp any any eq 5631
access-list 101 permit tcp any any eq 5632
access-list 101 permit udp any any eq 5632
access-list 101 permit tcp any any eq 5800
access-list 101 permit tcp any any eq 5900
access-list 101 permit udp any any eq echo
access-list 101 permit udp any any eq 20
access-list 101 permit udp any any eq 21
access-list 101 permit tcp any any eq 22
access-list 101 permit udp any any eq 22
access-list 101 permit udp any any eq 23
access-list 101 permit udp any any eq 25
access-list 101 permit udp any any eq domain
access-list 101 permit tcp any any eq domain
access-list 101 permit udp any any eq 80
access-list 101 permit udp any any eq 110
access-list 101 permit udp any any eq ntp
access-list 101 permit tcp any any eq 123
access-list 101 permit udp any any eq 372
access-list 101 permit udp any any eq 443
access-list 101 permit udp any any eq 550
access-list 101 permit tcp any any eq 550
access-list 101 permit tcp any any eq 1984
access-list 101 permit udp any any eq 1984
access-list 101 permit udp any any eq 6346
access-list 101 permit tcp any any eq 6346
access-list 101 permit udp any any eq 8383
access-list 101 permit udp any any eq 8484
access-list 101 permit udp any any eq 8385
access-list 101 permit udp any any eq 9595
access-list 101 permit udp any any eq 5800
access-list 101 permit udp any any eq 5900
access-list 101 permit tcp any any established
access-list 101 permit udp any eq domain any
access-list 101 permit tcp any any eq 3306
access-list 101 permit tcp any any eq 1723
access-list 101 permit icmp any any echo
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any ttl-exceeded
access-list 101 permit icmp any any source-quench
access-list 101 permit icmp any any time-exceeded
scoclayton Wed, 11/05/2003 - 10:39
  • Gold, 750 points or more
Wow, heck of ACL. Anyway, try adding the following:
permit udp any any eq 67
permit udp any any eq 68
I think IOS chnages these to bootpc and bootps but I cannot remember. The above should work as well. Good luck.
Scott
synbat Fri, 11/07/2003 - 13:46
Looks like that worked! Thanks! :)
