Warning message
rleguede Thu, 11/06/2003 - 01:20
Hi!
Nat can carried all UDP and TCP traffic. You have to set a static mapping (NAT) for your needed traffic.
You have to set the command look like below on your home router:
ip nat inside source static tcp IP@-A "Exceed tcp port" IP@-B "Exceed tcp port" extendable
Where IP@-A is the local address of your Exceed client station and IP@-B the public address of your home router.
Find the the port used by Exceed and replace "Exceed tcp port" by this port number.
